JMB RetrofitsEM Tuning
Results 1 to 10 of 10
Thread: Strange problem
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Strange problem
    Looking for some help with a problem my car seems to have,
    Some times when driving the car seems a lot faster than it usually does, ie I can drive the car and it seems fast enough but then all of a sudden the car tends to be a lot faster!!
    Its like the car has a chip that is working sometimes but not always??
    Any ideals?
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
    landopanda's Avatar
    Apr 2009
    Wiltshire
    143
    Could be the Maf?
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Shall I just clean it to find out??
    landopanda's Avatar
    Apr 2009
    Wiltshire
    143
    You could do, I think VCDS should be able to tell you if you plug it in.
    Or you can just unplug it and drive for a little way and see if it makes any difference then you would know.
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    So if I unplug the MAF and drive the car what should I look out for?? will the car be slugish??
    Yonner's Avatar
    Feb 2009
    Oldham
    150
    hi mate i had same problem, If you unplug your MAF your esp light will come on but dont worry. The car wont run sluggish it just wont boost properly/aggressively, i replaced my MAF and it went like a rocket!
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    sounds like a coil pack problem, after my car was remapped my car did this & one by one the coil packs when until i just replaced the remander.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Thats the turbo kicking in LOL...
    Either maf or coilpack seriously though mate, get it on VAGCOM and you should get your answer then
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    I will get it checked on VAG-COM just trying to save a few ,
    If the car runs fine some of the time would that mean the coil packs are OK?? and is it worth cleaning the MAF just in case??
    Thanks for all the help so far :o)
    **lol just texted my uncle who has his own garage and he has VAG-COM **
    So im off to get it checked tomorrow
    Nov 2005
    UK
    1,688
    it wont bring up a coil pack issue unless the cylinder isnt firing, you would think if their all working then no problems but i did notice varying performance before the coils went. You could just wait & see if one goes then just replace the lot.
    wanted for 8L S3:
    Milltek system
