Volks AutosBadger5
Results 1 to 10 of 10
    AudiS3Quattro's Avatar
    Jan 2009
    201
    Help With Boot And Central Locking Problem
    I Had the annoying 3 bleeps a few weeks ago, and my central locking stopped working, I understand that this is the alarm control unit battries( under the subwoofer), Which can be fixed by replacing them or the alarm unit Its self.
    However Now, becasue the central locking isnt working I have to open the door with the key, but when it comes to open my boot with the key, the lock just seems the spin as the key turns, and therefore the boot wont unlock and open.
    Does anybody have any clues to why this might be happening and also is there a guide to repalcing the alarm control unit? , or do you recommend getting a grarage to replace it for me?
    Many Thanks
    Paddy
    EDIT: is this link below the same for fixing this problem with the s3.....................? If so i think i may get a garage to do it!
    ALARM NOT WORKING-TT-
    Kingston's Avatar
    Jun 2009
    Preston
    182
    Hi mine played up i just took all the connections off cleaned them up and now it works spot on. Connections where very dirty
    Nogaro Blue 2001 S3 Quattro, Cream leather interior. Miltek Cat back, Induction kit, KO4 Hybrid Turbo, Chipped Remap, Power Boost Valve, Forge RC DV, Compbrake Racing 4 Pot Calipers with 2piece 350x32mm Conversion Front, 2 piece 330x20mm Compbrake Conversion on Back, Discs are Powervane Racing Rotors Gas slotted and internally veined. Hawk Hps Pads, Goodridge Braided lines to Calipers. Bose Symphony sound system. Compbrake Quickshift and side shift. Big thanks to www.Vagperformance.co.uk
    Jan 2009
    201
    Quote Originally Posted by Kingston View Post
    ah! great thanks for that, was it hard to access? did u have to remove the sub?
    Kingston's Avatar
    Jun 2009
    Preston
    182
    Was abit of a pain didn't take the Sub out. My pump/motor was there in front of the sub when i took the panel off it had a tie wrap on it. I just cut that off pulled the connections off it not much space i may add cleaned them up put them back on and all is fine. I havn't tie wrapped it back on though as it seemed to be pulled to tight. Not the easiest places for working i was lucky my boot still opened.
    Jan 2009
    201
    haha yer thanks for that, mayby i will trya nd get in the boot with a light through the rear seats!
    Appreciate your help!
    Kingston's Avatar
    Jun 2009
    Preston
    182
    No probs mate good luck climbing over the seats.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    You can see the pump by opening the cover thats in the boot over the passenger side wheel. The pump is covered in grey foam with a cable tie round it. It's recommended to remove part of the boot trim to be able to get the pump in and out easily.
    Also I dont want to be a party pooper but if you require a brand new pump it will set you back 300 from the stealers and it will need to be coded to your key signal too. Mine needs replacing so i'm getting it done by a specialist.
    If you're lucky then it could just be the cogs in the motor and you can get a recon kit for the pump off ebay for under 100. You'll need to get it checked out mate.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Jan 2009
    201
    thanks for that, yer i am goin to get it checked out by a specialist!
    many thanks
    Paddy
    Kingston's Avatar
    Jun 2009
    Preston
    182
    How you get on?
    mad max's Avatar
    sixth gear
    Jul 2006
    beyond the thunder dome
    335
    how did you clean them up
    S3 TUNED AT MRC
