Sky InsuranceVolks Autos
Results 1 to 10 of 10
    Jun 2009
    17
    New member needing some help
    Hey folks, had a problem with the car this morning and came across this site after looking for some info on google. So I'm hoping somebody here might be able to help as payday is 2 weeks away
    The car is a 2002 S3 with BAM engine.
    Driving home from work yesterday I stalled the car in traffic. The engine had to turn over for a few seconds before it started again. After it started there didn't seem to be any other issues and I made it home okay.
    Then this morning, car started first turn, driving into work and it misfired, about a minute later the oil pressure light came on and the car started to limp and eventually died. Checked oil level and no problems there. Tried re starting but the engine kept turning over but wouldn't fire, if you know what I mean?
    An hour later, after letting the engine cool down, it started first time. I checked the coil packs and one of them was a bit loose. The top of the spark plug had some soot on it from arcing. I reseated the coilpack and car seemed to be running ok.
    On the drive home the car misfired twice but it didn't die. Would this be because of the soot on the sparkplug? I'll have a socket tomorrow to remove the plug and I'll be able to VAG.com it on Friday.
    Sorry for the long post, just wanted to give as much info as possible
    S3 HODGE's Avatar
    Brown passenger seat.
    Apr 2009
    Dorset
    1,177
    Hi and welcome, Yea coilpacks are a common fault on VAG cars....Tell us the results of the Vag-com cheak when youve done it.
    The One And Only Brown Bora
    Current: 2007 S3, Solar Orange - Revo Stage1 + all the toys
    Sold: 2000 S3, Black
    Sold: 2003 BAM Nogaro Blue S3, Revo Stage2, 19" Rial Daytona's, AP Coilovers
    Sold: 2001 A3 1.8T
    Sold: 2002 A3 1.8T, Custurd Code, BBS CH, AP Coilovers
    Sold: 1999 A3 1.6, Jewish Racing Gold, S4 Wheels
    Xbox live ID: o_HODGE_o
    PS3 live ID: Hodge_09
    Jun 2009
    17
    Update
    So I checked the sparkplugs. Found the plug with the loose coilpack wet. Replaced coilpack and all plugs.
    The car ran ok for an hour, then emissions and epc light came on.
    Got the car on vagcom and it give lamda and crankshaft positional sensor faults.
    Replaced both sensors and the car's running alot better now.
    Jun 2009
    17
    Question
    I've got a new problem now though.
    The car used to idle at around 900rpm. Now after the engine warms up, the rev counter is jumping between 900 and 1000 rpm.
    Any ideas of what would cause this?
    Keeno's Avatar
    Spooly Spooly Boosty Boosty!
    Apr 2009
    West Sussex
    695
    Does it seem to jump suddenly then die down? almost like it's been cam'd?
    I only ask cos mine sometimes does the same, can't help with a solution though!
    Cheap and Reliable is not Fast. Cheap and Fast is not Reliable. Fast and Reliable is not Cheap!
    Jun 2009
    17
    no its more of a steady up and down if you no what I mean
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    Possibly the temp sensor, when they go they can cause idle revs hunting.
    2003 Audi S3 + Go faster bits
    Jun 2009
    17
    Okay, thanks. I'll try and get it on vag.com during the week. How much would a replacement cost?
    Yonner's Avatar
    Feb 2009
    Oldham
    150
    Temp sensors are about 15 -25 mate
    I replaced mine to fix that problem
    S3 HODGE's Avatar
    Apr 2009
    Dorset
    1,177
    I think my temp sensors on the way out as mine does the same on idle and sometimes drops to 80c when im crusing
    Sold: 2001 A3 1.8T
