EM TuningChris Nott
Results 1 to 7 of 7
    TanyaS3's Avatar
    May 2003
    UK
    205
    Intermittent Boost / Overboost
    Hello!
    Its been a while...... but I need some help please.............
    My S3 has a problem with intermittent boost. It will either not boost at all or massivley overboost to 25lb !!!!. Ocasionally it will boost normally. I also notice that the wastegate seems to chatter different amounts randomly (either a very small amount or fairly audible). The ambient temprature seems to make no difference. Has anyone else had this problem? Any help would be appreciated.
    Tanya
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Could be the N75 valve, dumpvalve or N249
    TanyaS3's Avatar
    May 2003
    UK
    205
    Thanks.
    I have spoken with Audi parts regarding the two valves. N75 and N249 seem to denote a number of different solenoid valves in the system. Is there anyway to figure out which valves I would need to replace ?. The car has been checked on with a diagnostic tool. The system displays : -
    01 - Engine electronics
    8N0 906 018
    1.8L R4 5VT
    Coding 5610
    value above maximum charge pressure
    Any info much appreciated
    S3 Paul's Avatar
    Oct 2006
    2,764
    Idealy you need to use vag com to check/ log the figures,
    Where abouts are you??
    I changed most of the control solanoids on my car ( it isnt cheap to just start changing things in hope )
    Noggy Blue 2001 S3
    TanyaS3's Avatar
    May 2003
    UK
    205
    Hello, changed a part, I think N75 located at top of engine under cover and it all works fine and is holding boost nicely
    thanks for your help and advice
    Tanya
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    sounded like dv problem. This is at top of engine.
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    The N249 valve is the one ontop of the engine under the cover, the dv and N75 are both located on the tip.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
