good point Ash..... i noticedupon closer inspection yesterday that theres two pipes leading into the plastic valve, im guessing the other drops into the bottom of the block to give afeed back for the oil? is this the case do you know?
Dani, good place to mount is on the bat box mate, run two 90 degree bends, 1 off the rocker cover and the other off the pipe you disconnect....then 2 pipes to the tank...simples i think if yuo can redue them easy enough
