Dennis Moeller
I went in today for a full alignment and did get the car corrected a fair bit. See the Suspension setup sticky for further values! But then it all stopped when the shop tried to adjust the rear camber. They couldn't correct it to more then roughly -2.00 degrees. I was really surprised because I had the Forge adjustable tie bars fitted (replaced the lower OEM tie bars) so I expected them to correct it to -1.00 degrees at both rear wheels. There was just no way.
What should I do now? Is it wise or even realistic to swop the adjustable bars which are now replacing the lower arms to the upper position. And then adjust the wheel outwards at the top...
Help...Trackday on saturday/sunday is heavily jeppardized!!
Any help mucho appreciato...
