how much oil should i be putting in? i no this sounds a pretty basic question, just my low oil waring light came on, so i put a litre of oil in last last week and today i bought 4 litres and put it in, thinking that the car would take around 5 litres in total, but after putting 3 litres in i stopped and checked the dipstick and it was miles above the max limit sign....
will this drop once the car has been driven? or have i put far too much oil in?
thanks
paddy
I'd be a little concerned about being miles above the max mark...like JJBS3 said, I think it's 1 litre between min and max. If your light came on I'd think 1.5 litres would suffice maybe 2, you've put in 4 in total plus what was already in there...sounds dodgy, I'd be inclined to drain some out personally...
what damage would over filling cause? and how do i drain some out?
Too much oil cna put pressure on the PCV system, causing it to pressurise and flood oil into the engine where oil isnt supposed to go thus causing cat damage and blocking pipes. If extreme it could even hydraulic and prevent the engine from starting.
However, 1/2 litre over will do you no harm, anymore, do the filter drop, £3 for peace of mind.
Change the filter. Takes quarter of a litre out with it, doesn't cost much either...
