Badger5AH Fabrications
    Nic
    May 2009
    Essex
    47
    More help needed please!
    I've just noticed that none of my break lights are working, does anyone know what it could be?
    Sorry if I sound a bit dumb but I've only had old Fords and know nothing about Audis
    Nic
    May 2009
    Essex
    47
    I've checked an old topic and the fuse is o.k. so it must be the switch. Can someone tell me if this is the right switch I need
    http://www.eurocarparts.com/ecp/c/Au...9b137b4bff1ec9
    Thanks!
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Hey Nic, i believe that is the right switch and it sounds like it is the switch thats causing the problem if the fuse is ok, PM pjmspeedy if you want to, he can get parts as well and may be able to help you out.
    Hope that helps, also if you have VAGCOM, it maybe worth getting it scanned to see if it brings up any faults.
    Nic
    May 2009
    Essex
    47
    Thanks for that, hopefully I can get one tomorrow
