Sky InsuranceVolks Autos
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    A3 1.8T Possible Limp Mode?
    hey guy, whilst driving my car to work this morning, i noticed there was a missfire. It did it for a few seconds then was ok for a few seconds. Then when flooring it over 3k rpm`s it miss fired badly in all gears. I let it cool down and then re-started it this afternoon and it was fine. Ive done a few searches and people say dirty maf, Coil packs and maybe Ignition amp. Ive cleaned maf conectors and ignition connections just to be on the safe side. ive also run it on Vag-Com with no faults. Any ideas if it went into limp mode and if so what are the symptoms of limp mode even when VAG-Com didnt store any faults.
    thanks in advance
    Audi A3 1.8 Turbo, Wietec Ultra GT 40mm kit, 3" Full Custom Stainless Steel Exhaust, Custom Code stage 1 remap, 17" RS4 Alloys, Whiteline ARB
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    tried cleaning the Throttle Body?
    ^^ In my opinion
    Aug 2004
    526
    In limp mode it would have no puff whatsoever.
    Could be a coil pack giving up the ghost which might not show up in VAG-COM till the prob develops. Other usual suspects - plugs, MAF, DV.
    Wouldn't throttle body produce lumpy / dipping idle?
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Throttle body? not sure it would be that as it would do it all the time wouldnt it? it seems fine now. whats the best way to check if its a coil pack?
