Badger5EM Tuning
Results 1 to 10 of 10
Thread: Esp or not?
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    Esp or not?
    Hopefully someone can help me...
    I have a 1997 1.8t, no esp button or light on the dash. However there is a noise coming from the front of the car when the wheels let go. I first noticed it the other day as I pulled out on a roundabout, the wheels started to spin when i put it in to second gear. I have tried several atempts on private roads since then to light the wheels up to see if I have esp, the wheels do light up but not as easy as i would have thought.
    I've had cars with traction control before and genearlly you can feel the engine hold back when the system is activated. The a3 sounds as if a system is being activated but nothing apears to happen, is this my abs system flipping out because the wheels are at different speeds or do i have esp?
    The sound is very similar to the abs sound when you plant the brake pedal.
    Anyone else with the same model got any ideas?
    thanks in advance
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    I think this was discussed a week or two ago. I think if you dont have the ESP button or light on the dash then you dont have ESP!?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Essflee's Avatar
    Mar 2008
    2,007
    You haven't got ESP, my old A3 used to spin up no worries in the wet...
    revo'd
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    any ideas what the noise is then? It must be abs related as it sounds very simimlar to when the abs kicks in.
    A3ster's Avatar
    Oct 2008
    87
    I have had the same noise twice now, usualy when turning and flooring it, never had it in a straigt line yet. First time my heart sank I had only had the car a couple of weeks but no adverse effect from it happening. Would be interested if anyone has any ideas? Could it be bearings or am I barking up totaly the wrong tree
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    CV joint possibly.... especially if you are anything other than steering straight
    <tuffty/>
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    I've checked the cv's, driveshafts, diff, my noise sounds electrical, like a pump activating.
    I suppose delving deeper it could be play on the output or lay shaft within the gearbox, but there's no way i'm stripping the box apart. I'll live with it until something goes pop. Just another joy of owning a car.
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    Quote Originally Posted by A3ster View Post
    Bearings tend to be a whirring or rumbling noise, normally present above a certain speed getter worse as the speed increases.
    A3ster's Avatar
    Oct 2008
    87
    Ahh, showing my lack of knowledge there
    Feb 2008
    Manchester
    158
    i saw something on this forum a while back that said a pre facelift A3 (no ESP Button) had an automatic ESP control up to a certain speed 15-25mph, (i think). I hope i havn't read incorrectly! My A3 used to do it before the remap! I've got to admit the first time i heard it i thought thats got to be bad! please keep us posted if anyone finds anything different!
