EM TuningAH Fabrications
Thread: Cruise Control
    Nic
    May 2009
    Essex
    47
    Cruise Control
    A couple of days ago my cruise control stopped working. Has anyone else had this problem and do you know if it's a big job to sort out?
    May 2008
    68
    Possibly the switch on either the clutch or brake pedal
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    The main parts aren't expensive, as mentioned above.... the clutch and brake switch play a big part. If your brake lights come on and off ok, I would look at the clutch switch but tbh I would VAGCOM it firt to see if there are any fault codes.
    Mine would occasionally switch off for no apparent reason, hitting resume would kick it back in and VAGCOM picked up a fault with the brake switch which I have now changed.
    <tuffty/>
