EM TuningJMB Retrofits
Thread: temp warning
    evilbow's Avatar
    Wheels urgently needed
    Feb 2009
    glasgow
    183
    Unhappy temp warning
    hi a few mins after starting my car today the temp warning light and audible alarm came on, but no way could it have even been to normal running temp as was only started for 2mins when this happened. can anyone shed some light on this for me? it did go of when i stopped engine then restarted car, but would like find out now incase its a underlying fault i want ot get on top of now!
    thanks in advance
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Check the coolant level, pull the plug off the side of the expansion tank and clean the connections and refit it. used to do it on mine now and then and its been fine since I cleaned the plug.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Probably just low coolant, the sensors are generally reliable enough.
