Badger5EM Tuning
    Jay
    Aug 2006
    323
    Question for those who have bypassed the N249 valve
    I did this 'mod' a few weeks ago and recently started to hear chatter when coming off boost. I've got the 007p fitted so knew it couldn't be that. Had a look under the cover and found the heat had caused the vacuum pipe to fold onto itself where it comes out of the top of the DV. Managed to sort the problem out but looking to get some better quality tubing. I'm using 4mm at the moment and was wondering what difference 3mm would make, if any?
    What size have people used when doing this mod?
    Jay
    Aug 2006
    323
    Anyone?
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,108
    What is gained by bypassing this valve ??? i've not heard of this mod before.... and where is it located ???
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Jay
    Aug 2006
    323
    N249 Fault?
    well worth doing if you've got boost problems.
    Tastyterrier's Avatar
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    I've used 5mm proper silicone tubing as a temp fix for a faulty N249. Sorted the problem straight away, however the N249 is a safety system against overboost, so I'll be replacing it and then getting the N75J back on
    A3 1.8TQS: Supersport Springs and Shocks, Xenons, BMC Filter, 18" OEM TTV6's, Bailey DV, N75J and Phase 1 Custom Code.
    Jay
    Aug 2006
    323
    I was thinking maybe a smaller tube would give better throttle response?
