    CJA318T's Avatar
    Mar 2007
    Birmingham, West Midlands
    74
    VAGCOM Fault codes query
    Hi Guys,
    I've got an A3 1.8T and have recently been throwing up some fault codes.
    16486/P0102/000258 - Mass Air Flow (MAF) (G70): Signal too Low
    17544/P1136/004406 - Fuel Trim: Bank 1 (Add): System too Lean
    both probably because defective MAF??? thoughts? (car has done 93k miles). Easy to rectify/fix?
    17055/P0671/001649 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
    I thought only diesel engines had glow plugs? am i being really dense or is there something else i should check out?
    Any advice would be great, cheers
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    first place to look mate is here: http://wiki.ross-tech.com/index.php/...ry:Fault_Codes
    I'd guess that if the maf on your car is the original one then it may need replacing.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    CJA318T's Avatar
    Mar 2007
    74
    cheers for that.
    any thoughts on the very random glow plug fault?
    cheers
    Westy's Avatar
    Dec 2008
    17,156
    Cant help you with the glow plug issue mate I've never even heard of a glow plug before
    S3 Build Thread
