Volks AutosAH Fabrications
Results 1 to 17 of 17
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    Speedo not right
    A3 1.8t sport 5 speed 1997.
    My speedo is reading about 5 to 10 mph out. Looks like someone has had the clocks to bit before as the abs led is missing. Realating back to an old mot failure it seems someone has removed the abs light just to pass the mot.
    Moving on...
    Could someone please tell me what rpm they are doing to a certain speed?
    Or 5th gear at 1000rpm what speed are you doing?
    Or where does your needle sit when the ignition is off,
    i think i've made this sound complicated as always.. lol
    thanks in advance
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    its easy to find out if the clocks have been tampered with. Take out the speedo from the dash and look on the back of the clocks. There should be a paper white seal were the back white plastic meets the front black bit. If its brocken then i would say they have been tampered with. The red needles should sit on the zero when the ignition if off.
    Audi A3 1.8 Turbo, Wietec Ultra GT 40mm kit, 3" Full Custom Stainless Steel Exhaust, Custom Code stage 1 remap, 17" RS4 Alloys, Whiteline ARB
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    Quote Originally Posted by reptor245 View Post
    I've had them apart thats how i know the led is missing. Clearly someone has messed with them in the past. Vagcom is showing front right abs sensor, anoying that someone has messed the speedo up for a 15 part.
    Mine reads 70mph in 5th gear at 3000 rpm any ideas if that is right?
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    there must be someone who can tell me what speed they are doing in 5th gear at 3000rpm please! or any other combination of speed/rpm
    27,073
    Actually thats not true, they should sit at zero when the ignition is turned but car not started, they sit below the zero lines when the keys are out
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    thanks mate i'll have a look later.
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    really? I guess these are brocken then.
    http://cgi.ebay.co.uk/AUDI-S3-INSTRU...3A1%7C294%3A50
    http://cgi.ebay.co.uk/Audi-S4-Dash-C...3A1%7C294%3A50
    27,073
    I've dealt with several clusters & none of them have sat at zero when keys are out, bottom line is as above they should sit exactly at zero when the ignition is turned, so work of that
    No disrespect but you're quoting from pictures of ebay & given how small of a percentage they could be out & they are known to be between 5-10mph out anyway from factory, if you look close at these the needles on the speedo side are actually below the zero line & I hazard a guess when the clusters you show are installed in a car they sit above the zero line, also the S3 one fuel gauge is below the line, be factual not fictional & quote from a working cluster not of ebay links then I'll accept what you're saying as a fair comment.
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    I've dealt with several clusters & none of them have sat at zero when keys are out, bottom line is as above they should sit exactly at zero when the ignition is turned, be factual not fictional.
    heres a pic of mine with keys out.
    27,073
    Even your rev counter isnt level & speedo slightly of the mark, what about when ignition turned?
    Edit: you removed your post while I posted so amended mine.
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Specsavers mate, I'm not a mod
    Huh?
    its about 1mm below, just like the S3 one.
    mine
    ebay`s
    both mine with ignition on and ebays with ignition clearly off are the same. rev counter on the dot and speedo 1mm below.
    27,073
    Well yours is different to my previous cars clusters then & the new 09 facelift white cluster I now have, but speedo should be spot on & no doesnt mean they're broken just not spot on correct, then again most speedo's are not 100% correct anyway, but if when ignition is turned on & they are all on the actual zero line not below or above then your closer than most, but to help the guy asking just make sure they're on the line then see if you still think they're out, even the smallest amount makes differences given the dial measurements of speed, clusters seem to be non uniform tbh when you'd expect them to all show same characturistics interms of where the needles sit etc, but alas.
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    I'll check later, thanks for your help.
    Ellisium's Avatar
    Aug 2005
    Liverpool
    11
    Quote Originally Posted by ash_pearce View Post
    Checked this earlier and speedo read 73mph (private road of course haha)
    My cars got 18" TT's on which would make a difference but thought I would post this as a start
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Have you got access to a satnav? Could get speed from GPS then
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    Quote Originally Posted by Ellisium View Post
    thanks mate looks like i'm not far off then.
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    Quote Originally Posted by Byzan A4 View Post
    no mate hate the damn things! cant beat a good old map.
