Volks AutosMonster Motorsport
    May 2009
    Question A3 18T sport problem
    hi every on im new to this forum and i am hoping some one can help i have an 18T sport and yesterday while driving it cut out i stuck my computer on and got these codes
    1250- ------- Injector for No. 2 Cyl. (N31)
    Short to Ground INTERMITTENT
    1251- ------- Injector for No. 3 Cyl. (N32)
    1252- ------- Injector for No. 4 Cyl. (N33)
    1247- ------- EVAP canister purge regulator valve (N80)
    1262- ------- Wastegate Bypass Reg. Valve -N75
    16486 (P0102) Mass or Volume air Flow Circuit Low Input
    INTERMITTENT
    16519 (P0135) O2 Sensor Heater Circuit Malfunction (Bank 1 - Sensor 1)
    INTERMITTENT
    to me that suggests a bad earth or am i wrong ? (ive checked the earth by the battery and all is clean and good same with the engine side just in case it was) can any one help as this i my pride and joy thanks
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Check the wiring again and see if fuel pump relay is seated correctly. It's located under the driver's side dash. You will need to remove the lower part of the driver's side console to reach it.
    Check the heavy-duty fuses on top of the battery and check fusebox also.
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    Oh, it also seems that your MAF is on it's way out from 16486 error and your pre-cat lambda sensor had better days by the looks of things... Although, I'm not sure if these can be caused by related electrical issues with injectors.
    May 2009
    before all this the car was running fine had no errors as had checked it only 2 weeks ago
    May 2009
    ok tried the relays and no joy problem is still there but did notice another two relays getting warm very fast
    May 2009
    update
    issue resolved the fuel relay had a lose prong causing a short and bringing up all these errors
