Volks AutosEM Tuning
    Mar 2006
    lincolnshire
    254
    what they worth?
    got a set of front s3 calipers and carriers. ive stripped them back to the metal using elsectrolysis to remove all the rust. im thinking of either painting them (what colour?) or leaving them as they arr so the buyer can paint them the own colour. what do you guys think there worth?
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    The carriers will be worth more than the calipers I think, the single piston calipers are the same as those used on the facelift A3's with 1.9TDI 130, 1.8T & 1.8TQ IIRC.
    The only difference is that they have 288mm brake discs whilst the S3 has 312mm.
    At a guess I'd estimate about 50 ish, maybe a bit more?
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    i'll have them off you for 50, just what i needed!
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,617
    carriers are what the golf guys use apparently when upgrading their brakes,mine are sitting in my garage
    Mar 2006
    lincolnshire
    254
    i think ill stick em on ebay see what they fetch, you guys reckon its worth painting them to make them look a bit more appealing?
