Volks AutosBadger5
Results 1 to 10 of 10
    Shy19s's Avatar
    Oil running through my veins.
    Apr 2008
    London
    902
    What are the benefits of Drive by wire?
    Also, structurally, is there a difference between the BAM engine and the AMK engine? pistons, block, pins etc.. am i right in thinking the injectors and heads are very simular?
    The main difference is Electronic i believe but would the AMK engine stunt you from being able to get serious power?
    Also can you convert DBW to cable? would you want to etc?
    Thanks in advance
    Totally addicted to boost.
    Essflee's Avatar
    Mar 2008
    2,007
    DBW is supposed to be more economical, more responsive and less maintenance...generally a better system to use...as for the BAM vs AMK, seem to hear different rumours so don't really know...
    revo'd
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Are you sure you mean AMK? Mines AMK and it DBW... only real difference between BAM and AMK is the AMK is mapped for 210bhp... there are plenty of threads here wobbling on about BAM this and AMK that etc....
    Heres a post you might find useful
    http://audi-sport.net/vb/showpost.ph...4&postcount=15
    also this one
    http://audi-sport.net/vb/showthread.php?t=70895
    <tuffty/>
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by leggy View Post
    No way is it more responsive than a cable connected direct from the throttle pedal to the throttle butterfly with instant response.Dont see how it can be more economical but stranger things have happened.Less maintenance,how much maintenance is on a throttle cable?
    If it was a better system to use why do people buy sprint boosters?
    http://www.sprint-booster.co.uk/what...nt_booster.asp
    Essflee's Avatar
    Mar 2008
    2,007
    Because the pedal is controlled by the engine management system through electrics and sensors as appose to cable the bet use is made for the amount of air comming in which gives better response and economy... I agree people use the sprint booster which helps response, this is what I was led to believe though...
    revo'd
    Dennis Moeller's Avatar
    Jan 2007
    NorWay
    442
    Regarding DBW...I believe I have it on my AMK and I suspect it to cause this: coming off the gas when I change gears it keeps the engine revved. It takes forever (well not forever, but it's around 0.5-1 second) for the rev's to drop and it happens soooos slow. That really irritates me. Sounds as if I'm not lifting the foot from the gas pedal fast enough...like and old man When I blast it it's not a problem because the gearchange is faster and sound / speed are higher...
    But driving normally it does take at bit for the rev's to drop...sometimes it even raises the rev's a couple of hundred RPM's before dropping. Not excactly what I want from a car. You have the same issue?
    The sprint booster is not for me, I think, I don't want the ON/OFF gass pedal effect and are quite happy how I can control when I want boost.
    My old car.. Still miss the lil rocket :-)
    Remapped Stage II - Forge FMIC - Dahlb�ck Intake - K&N - DieselGeek ShortShift - Phenolic - Powerflex Dogbone - Rial Daytona Race 8.5x18" ET30 - Forge Tiebars - Bilstein B8 - H&R 25mm - R32 rear ARB - H&R 20mm Spacers - EBC Discs - Red Stuff pads
    ______________________________________________
    NO ONE EVER REALLY DIED
    dstructiv's Avatar
    Feb 2009
    34
    lol sprint booster, another resistor in a black box, like all the maf and other +20bhp adverts on ebay. you cant make an electrical signal quicker than it is especially when an ecu is involved.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Whats the APY engine run?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    ALL 8L S3's are DBW, mine has to be one of the earliest S3's about, APY engine code on a T-plate with no ESP or traction control, and it's DBW.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by dstructiv View Post
    Nothing like the +20 bhp ebay crap and neither does it make the electrical signal quicker,what it does as far as i can tell is alter the signal so the ecu thats involved opens the throttle plate faster and further than normal.Simples.
