Volks AutosBadger5
    s3 tys
    Oct 2008
    St austell, Cornwall
    88
    forge splitter r
    hi all am currently running a forge splitter r valve on my s3 at 16clicks as forge recomend and have noticed it holding off after bout 4500 rpm have had a new maf sensor put in by audi 2 weeks ago so not that used to run fine with old bosch valve am thinking now just putting a forge 007 on instead would it be the valve or something else wrong cheers
    S3 Paul's Avatar
    Oct 2006
    2,764
    I would surgest having the car hucked up to vag com or something like that. This will show it you have a problem anywhere else.
    I swapped back from a splitter r to a 007 as i had boost leak issues and wish i didnt, It made no diffrence as my problem was with a vac pipe under the inlet manifold
    Noggy Blue 2001 S3
