Chris NottAH Fabrications
    rik_t2005's Avatar
    Apr 2009
    wolverhampton
    11
    sony stereo and the back speakers not workin
    just put a sony stereo in my 8l cuz someone has tuck the audi 1 out and the back speaker r not workin any1 no why
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,373
    not sure why, but a friend of mine tried a sony cd/mpg player in his 8L A3, and just like you, the rear speakers didn't work. Only the fronts.
    the sub in the back also didnt work, although I'm not sure the rear speakers are linked to it.
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Sounds like you both have the standard non-bose system in the A3 which uses a separate amp in the sub enclosure to power the rear speakers, and IIRC the sub, while powering the fronts off the head-unit's amp. If you change the head unit, then the feed to this external amp is no more, so you have 2 basic options:
    1. Run new cables from the rear speakers back to the rear amplified outputs on the new head unit
    2. Buy a cabling adaptor that goes behind the head unit to send the signals back to the Audi amp in the sub enclosure in the boot, although the standard amp is low powered compared to the head unit's built-in amp, so you are better off with option 1.
    There are other more exotic options, like a new amp and an AndyMac stealth sub, but all that requires some more new cabling, and costs money naturally. Depends what you are after and what you are prepared to spend.
    A search on the forums for 'a3 rear speakers' brings up plenty of discussion on this sort of problem.
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Quote Originally Posted by rik_t2005 View Post
    you cant just chuck in a sony head unit without the correct adapters. you need one of these
    I had the excat same problem but this kit sorted it.
    http://www.nexxia.co.uk/Car_Stereo_f...ts/audi/A3.htm
    simple solution without all the crap.
    Audi A3 1.8 Turbo, Wietec Ultra GT 40mm kit, 3" Full Custom Stainless Steel Exhaust, Custom Code stage 1 remap, 17" RS4 Alloys, Whiteline ARB
    rik_t2005's Avatar
    Apr 2009
    wolverhampton
    11
    thanks every1 ive put some 6x9 in the rear cards and powered them of a new amp but thanks 4 the help
