A3 suspension upgrade advice please
dan77
dan77
Down south,
hey guys im considering upgrading my standard suspension to a weitec 40mm gt kit:blackrs4:, and possibly some new ARB`s is there anything else worth replacing while everything is of, also will this "tighten up" the steerin as it feel a bit loose and wobbly
New ARBs should come with new bushes, I changed my rear axle bushes and also the front wishbone bushes when I had mine done.
The Wietec kits nice, the 40mm is about for an A3 so I'm happy with mine.
What ARB's are you looking at?. I can rate the KW 23mm front and 25mm rear kit. No body roll and handles like its on rails now :D
The Weitec kit and ARBs will make a massive difference. I'd check top mounts and all the usual bushes to make sure they're not too worn while you're on with the rest of the suspension.
Damian @ DPM
