Volks AutosMonster Motorsport
Results 1 to 15 of 15
    Apr 2009
    12
    Question Standard boost pressure
    Hi everyone ive just fitted a turbo boost gauge to my audi s3 210bhp that's on a 2001 (Y) and was wondering what psi it should be boosting on
    Thank You.
    Essflee's Avatar
    Mar 2008
    1,995
    Standard would be about 15-16 psi...
    revo'd
    Apr 2009
    12
    10 psi max
    Im only getting 10psi max but i have no leaks at all due to they have all been tested any idea why its so low thanks
    Essflee's Avatar
    Mar 2008
    1,995
    Sorry, should be about 14psi...your low figure could be down to the maf possibly...a friend was getting lower boost figures with his S3 and it turned out to be the maf...
    revo'd
    Apr 2009
    12
    ive just replaced the maf today with a new unit and also its been on the vag com which is showing know faults at all thanks
    Essflee's Avatar
    Mar 2008
    1,995
    If your not getting any eras thrown up and your sure you have no boost leaks then I don't know...your boost is in psi and not bar is it, don't mean to be funny but if it's 1.0bar then it's spot on...
    revo'd
    Apr 2009
    12
    no its defo in psi and reading 10 psi it had a full smoke test through the complete inlet system today and showed know signs of any leaks at all it also does feel a bit sluggish as well, going for a remap this weekend but is there any point with it being like this!!!!
    Essflee's Avatar
    Mar 2008
    1,995
    Whose doing the map for you ? If it were me as your not getting any fault codes I'd go for it, they should see if any problems make themselves known...maybe just what she needs...
    revo'd
    larsmate's Avatar
    Apr 2004
    111
    Quote Originally Posted by CHARGED UP View Post
    What does your boost pressure in VAG-COM read? Log block 115 which will give you requested versus actual boost. This will tell you if your boost gauge is accurate.
    Black S3 | MY09 | APR 3.1 Stage 2+ | RNS-E Mk2 | Tints | Titaniums | APR DP | APR HPFP | WALK | H&R SPRINGS | Lamin-X | BlueVAG VAG-Check |
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    I thought Std boost on the AMK was 11-12 PSI
    Mar 2009
    124
    BSR - POWERFLEX - CATBACK
    Mar 2008
    Ipswichish
    127
    mine's a 210 ona '99 and only runs about 10-11 psi does feel slightly sluggish but put that down to my last S3 being remapped, will have to have a look at it now.
    '99 noggy blue S4 / '84 mk1 Astra GTE turbo
    ianysm's Avatar
    Oct 2008
    UK
    1,001
    DV, Actuator weak maybe?
    See what the tuners say when its mapped
    P.S. They're all slow pre-remap!
    Current: RenaultSport Clio 172
    Previous: 2001 ('51) S3 Quattro
    Previous: 2001 E46 M3 Coupe
    Previous: 2001 Civic Type R
    Mar 2009
    124
    Take a pressure test with coloured smoke...
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    i've had my S3 for just over 3 years, i persumed it was standard when i bought it, fitted a boost gauge to it today, its boosting 20psi
