EM TuningAH Fabrications
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    Unhappy immobilizer light on - Car won't start
    Not sure what's going here, can't start the car the light is on the dashboard..have changed the batteries in the remote fob, but still no joy car doors open fine with the key, and start the car but it cuts straight away. Any ideas fellas??
    A3 TDI Sport 00
    A4 TDI Sport 04 Alacantra, Fishscale alu trim, GmbH bodykit, 6 speed box.
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Have you tried another key if you have a spare?
    Could be a problem with the immob receiver, which isn't sensing the key signal. A friend at work has a 2001 TT, which does this intermittently and moving the keyfob about seems to fix it.
    I know it's not much, but hope it helps.
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    Quote Originally Posted by leshkin View Post
    Alright mate
    i have tried both keys. it is intermittent i was thinking about getting the keys reprogrammed, but don't want to spend money at stealers and have the same issue later on.
    K
    A3 TDI Sport 00
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    iirc, if the battery is low, the car won't start. It might be the problem. Not sure though. But as said above, it's normally the receiver to look at first
    do a vagcom scan and see if anyhting comes up
    ^^ In my opinion
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    just read this (it was on a tdi too)..not sure how much it will help
    http://uk-mkivs.net/forums/p/259148/...3.aspx#1697153
    ^^ In my opinion
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    The bttery strength is irrelevent to the immo system as thats handled n a different manner. It may be worth checking the connections under the steering column as sometimes they can casue problems, or as a temp fix, push the steering wheel slightly closer to the dashboard, that can allow you to start the car sometimes as the loom is no longer being tugged upon
