AH FabricationsChris Nott
    A3-sport's Avatar
    BOSE
    Mar 2009
    197
    Passenger door speakers not working (3dr)
    As above... anyone help with what might be wrong - its the standard stereo but the passenger door speakers dont work....
    FOR SALE: A3 (8P) Car Mats - Front pair & full set - BRAND NEW
    2004 onwards: for the 3-door, Sportback, quattro and cabriolet versions.
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    For starters, do you have an amplified system? My old 1.8T Sport had the rear speakers that were amplified by a crappy bose amp. Check if the fuse has gone on this?
    Other thoughts: Wiring to speakers/amp OK?
    To be honest, if both the rear speakers are not working, I'd be checking things that are common to both of them, which would be the connections from head unit, amplifier, fuse for the amplifier, etc...
    Have they ever worked or have they stopped working recently?
    AndyMac is probably the authority on this, but the above should get you started.
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    Actually, I just re-read the thread title... I'd check the wiring/connectors if I were you
    A3 1.8T Sport
    Mar 2009
    Plymouth
    77
    Before I got a CD Changer I was using one of those MP3 -> Tape converters, for some reason when I used this there was no sound from the passenger side.
    Do you get passenger side sound when listening to the radio?
    A3-sport's Avatar
    BOSE
    Mar 2009
    197
    Quote Originally Posted by Mings View Post
    Well my cd changer doesnt work - so I have to listen to the radio. The elec windows, central locking etc work in that door so its just the sepakers in the passenger door not working.
    Shy19s's Avatar
    Oil running through my veins.
    Apr 2008
    London
    902
    As said before first thing to do is check the connections at the speakers..
    Take your door card off, unscrew the speaker then while connected push down on the cone, if it then makes a noise, you need new speakers.
    Id also check someone hasnt gone to the back of your headunit with some wire cutters.. white and grey wires are for the front speakers(2 each, neg has a black line down the middle), make sure they're intact with the ISO block.
    Totally addicted to boost.
