Chris NottAH Fabrications
    HOUCH's Avatar
    Aug 2006
    88
    A3 quattro rear caliper problem
    Hi there looking for advice on the rear piston on my caliper, changed front disc n pads no problem but rear piston in caliper does not seen want to screw back into housing, rear pads pretty worn and disc also so piston got to go fair way back into housing removed hand brake cable and taken lid off reservoir ,not got "special" tool but using circlip pliers turning clockwise can get piston to rotate but does not want to screw back into housing? any tips or tricks I'm missing out on ? got to use car in am so put old gear back on but would like to sort? any help n adnice appriciated. Houch.
    Houch
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Buy the tool mate... I had the same prob. Used pliers to wind it in for ages to no avail. Borrowed a tool from a mate and took 30 seconds to wind it in...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    HOUCH's Avatar
    Aug 2006
    88
    hmm thought that may be the answer many thanks for post
    Houch
