EM TuningMonster Motorsport
Results 1 to 9 of 9
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Fault codes since remap
    Hi guys, more than anything i am hoping for clarification. Since the remap our 2001 A3 1.8TQS occasionally fails to start and then throws a code. It will start after several attempts once the ECU has decieded to power up (indicated by the ECM light illuminating)
    The secondary pump code is due to crash damage from when she first wrote the car off, so no worries there. The DV is a brand new 710N and all boost connections were checked when i was underneath doing the clutch at the end of last month so i assume its a generic code thrown as the boost requested and actual figures don't match.
    The concern is the ROM one, is that the bit that gets flashed when a car is mapped? And do you think this would casue the ECU not to power up?
    Codes as follows:
    Control Module Part Number: 06A 906 032 BJ
    Component and/or Version: 1.8L R4/5VT 0002
    Software Coding: 10710
    Work Shop Code: WSC 00000
    Additional Info: blah blah blah
    4 Faults Found:
    16989 - Internal Control Module: ROM Error
    P0605 - 35-10 - - - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    16795 - Secondary Air Injection System: Incorrect Flow Detected
    P0411 - 35-00 - -
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-10 - - - Intermittent
    Apr 2004
    12,523
    anyone have any ideas? Its the Failing to power up an the ROM error that gets me. What else would stop the ECU powering up? And then would that in turn make it show bad ROM, or vice versa?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    you've got a chippeduk map if i'm not mistaken? My one throws an overboost error now and again due to the requested and actual boost not matching but I think you need to investigate the Rom and voltage errors.
    The ross tech wiki says the following for the voltage error:
    http://wiki.ross-tech.com/index.php/18010/P1602/005634
    but there's nothing on the ROM issue. You could email ross tech and ask them about that code?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Maybe your ECU is on it's way out? Read somewhere on VWvortex that this a possible problem with the ECU and might need replacing, but some reported that getting the map reflashed by the company, who originally mapped the car fixed the ECU error.
    The above could also be cased by your battery's bad wiring or battery itself being on it's last legs, as per Westle's post, so I would sort that out first and see if the ecu code comes back after clearing it.
    Apr 2004
    12,523
    Cheers, they both come back sadly. I am still trying to track the ECU/Wiring power fault as when i goes the car wont start. The ROM one i am hoping a re-flash will fix it as surley the ROM is the bit they flash?
    I have replaced the ECU relay located under the bonnet, any other suggestions?
    Oh and thanks for the replies so far guys
    Westy's Avatar
    Dec 2008
    17,283
    Have you tried another battery just in case?
    S3 Build Thread
    Apr 2004
    12,523
    Batery isnt very old and holds charge fine, cranks the car over for ages no probs, the charging system works too according to my trusty old multi meter, but i may swap the a4 one in to be 110% sure its ok
    27,121
    Check elsa to see if terminal 30 has connections to the other parts like secondary air pump etc & if so this could be the problem there, also check ignition, see if this is also on the same term 30 circuit mate, just an idea, but if you're saying only after the map these came up I'd get the map company to reflash or return the ecu to stock & then check for the codes to see if they are caused by the flashing, I doubt its battery given turns over so well, but anythings possible, if the secondary pump isnt getting power then of course this will cause problems.
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    mines also shows
    Weird as i was also asked, has it been mapped? Altho has lambda b1 s1 fault and N112 open circuit, which may have something to do with the ROM error....if anyone else can shed some light it would be much appreciated Cheers
    Vehicle wrapping specialist
    NOW SOLD S6 Avant 4.2 V8....ooooo the noise hehe
    NOW SOLD '03 A3 TDi Quatty Sport Mods so far: Aerowipers front & Rear, Type R Sting ariel, 18" RS-TT Alloys, Superchips remap, Eibach Pro Springs -40mm, Bilstein B8 dampers, R32 ARB's Front & Rear, Pipercross panel filter
