    Apr 2009
    11
    Help with mods! - Re-map, filter and Dump Valve
    I have a 2001 S3 "AMK" engine code (210bhp i think)
    > What remap is recommended? I am based in WEST WALES (don’t want silly power 260-270 ish I was hoping for)
    > Also Which aftermarket air filter is best? (panel type I believe? but which one)
    > Im also a 'CHAV' who wants a slightly louder dump valve (I believe the Forge Recalculating is best for the engine, does it sound any different to standard though?)
    All help is appreciated from this VAG novice!!!!!!!!
    nickrex's Avatar
    Oct 2008
    45
    The 1.8t VAG engines dont have a dump valve. Its a recirculating valve meaning that it is designed to divert air back into the engine. If you were to fit a dump valve instead, the ECU would wonder why its not getting the correct airflow and probably throw up a fault code. This is why they are not noisy in the first place. The only time you get that "Dump valve chatter" is when the diverter valve is knackered!! Mine did this and although some may thing it sounds good, you are probably losing alot of power and should be replaced.
    Apr 2009
    11
    so a valve like this:
    http://cgi.ebay.co.uk/FORGE-FMCL007P...1%7C240%3A1318
    Is the same noise as standard but a BETTER quality one which is less likley to fail.
    bl_1969's Avatar
    Roads? We Dont Need Roads!!!!
    Apr 2008
    351
    Yeah, better build quality. You can also take it apart to clean it/service it yourself - can change springs in for different PSI should you remap I think. Better noise in my opinion but not loud like a dump valve that you spoke about before. Makes gear changes better for some unknown reason to me.
    Car: A3 1.8T QS (ARY)
    Mods: Revo Stage 2, Milltek, K&N, Forge 007p, B8's & Eibach Springs, 312MM OEM Brakes, BBS LM's, Light Pack, Ally TT Pedals, New Audi Gear Knob, Int LED's
    Wish List: ARB's, FMIC, Hose's, Maybe A Clean Engine Bay and Free Petrol
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    or you could go with this
    http://cgi.ebay.co.uk/FORGE-SPLITTER...1%7C240%3A1318
    it reciculates whilst also dumping a little bit, so you get the noise without ny lose of power
    Apr 2009
    11
    Quote Originally Posted by dela View Post
    Cheers, thats just what im looking for!!!
