Monster MotorsportVolks Autos
Results 1 to 10 of 10
Thread: front seats
    evilbow's Avatar
    Wheels urgently needed
    Feb 2009
    glasgow
    183
    front seats
    how easy is it to swap front seats over? is there anything i should look out for or beware of? any advice welcome! i'm swaping my tired old standard seats out an 1.8 8l a3 to a 1.8t sports seats please advise
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Very easy job. A couple of plastic covers to remove at the front and rear of the seat rails, and 2 bolts at the front. Disconnect any wiring (don't turn on the ignition while the airbag is disconnected!!) and lift the seat out.
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    Oct 2007
    Plymouth
    203
    just be carefull when you remove the plastic covers at the back of the rails, they break really easily.
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    if you fit heated leather seats to an a3 which didnt originaly have them how easy would it be to wire up the electrics?
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    anyone?
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    someone must know
    S3-Andy's Avatar
    Apr 2008
    198
    i could not say mate, but i know some manufactures will have the loom installed weather u have the option or not, it might be a simple case of plugging them in and fitting the switches in the dash, or you may have to fit the loom? i know a few year ago my dad had a vauxhall calibra with cloth trim, we swapped it to full leather and all the wiring was in place we just plugged them in and fitted the switches to the dash, have a look under your seats see if you have the plugs or even check your dash where the switches would go.
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    There are loom available as a retrofit kit to the seats, but I heard that it's a major pain to fit these as the trim is a little difficult to put back on.
    Apr 2009
    14
    my old corrado had the loom too, so it was just a case of getting the switches. hope that helps a little
    Audi OCD
    Sep 2008
    68
    I had the carpet out of my A3 1.8 T (99) and unfortunately there was no wiring in place for heated seats - just the airbag trigger units. But I think it would be easy enough to run a wire under the trim at the edge of the carpet and then feed it under the carpet to the holes that the airbag plugs come through without taking the carpet out.
