Revo TechnikBrotek
Results 1 to 12 of 12
    swatchuk's Avatar
    Nov 2008
    188
    Brake bleeding help!
    Hi, after some tips and advice on bleeding the brakes on my s3. Kinda ballsed it up today, emptied the whole system and then tried to pressure the new stuff through. kinda worked but pedal just goes to the floor.
    Anyway, can someone please tell me how to bleed the system properly? And I have access to vagcom if i need it.
    Thanks in advance
    22,588
    whoops, emptied, now system is gonna be fun now as its probably full of air, ideally need 2 people, one to fill up the reservoir, make sure it doesnt go below minimum at all, also they would check the fluid for air bubbles, cleanliness along with undoing nipples & doing up, the other to sit there, pump fluid through & hold the pedal in position when they're filling up the system & tying of the nipples, thats how we did mine recently, idealling using a non returning valve in a bleeding kit so it cant suck any air/fluid back in.
    I'm sure there are others on here that can explain it better, but thats what I remember from few weeks back.
    PARKING SYSTEMS - BODYWORK - PAINTWORK - WHEEL REFURB - DETAILING
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    swatchuk's Avatar
    Nov 2008
    188
    there was 2 of us doing it today, theres no air bubbles coming out of any of the nipples now but pedal still goes to the floor. Do I need to bleed it with the car running?? And ive read somewere about bleeding at the master cylinder??
    s3ollie's Avatar
    Jan 2007
    722
    if you havent done the MC then thats the first place to start. defo be air in there if its gone dry.
    8P S3
    swatchuk's Avatar
    Nov 2008
    188
    Right i'll give that a go tomorrow then. Cheers Ollie
    s3ollie's Avatar
    Jan 2007
    722
    theres 2 nipple on there one for each circuit bit of a ***** to get to!
    8P S3
    swatchuk's Avatar
    Nov 2008
    188
    were is the mc? havent even looked for it?
    s3ollie's Avatar
    Jan 2007
    722
    its in the engine bay opposite where the brake pedal is in the cabin, so in front of the steering wheel
    8P S3
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,811
    this is the guide I used on my A3....might help:
    http://forums.vwvortex.com/zerothread?id=3184085
    make sure ythe MC doesn't run dry because, iirc, you will need to get it on vagcom
    ^^ In my opinion
    swatchuk's Avatar
    Nov 2008
    188
    Right, problem solved. Bled the master cylinder (what a nightmare to get too), bled the clutch, and then worked my way round the car again! All done and working now. Fitted EBC turbo grooved discs, Ferrodo DS2500 pads all round, then used Motul RBF 600 brake fluid. Just drove it down the road and the difference all ready is great. Cant wait for them to bed in
    Thanks for all the help
    Nov 2006
    brake bleed
    Hi, how did you manage to get to the bleed nipples on th mater cyclinder and what spanner did you use was it a special brake bleed one or normal open end. Thanks Ray
    swatchuk's Avatar
    Nov 2008
    188
    I ended up just using a socket on them and then nipped them up after they'd released all the air. You can hear the air come out so not too bad.
