Monster MotorsportEM Tuning
Results 1 to 11 of 11
Thread: Aerial help
    S£'s Avatar
    Mar 2008
    Suffolk
    669
    Aerial help
    Check this out, hardly anyone looks on the ice forum..
    S3 Aerial connection
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    the ICE section is more players innit?
    A3Gloss's Avatar
    Mar 2009
    Yeah should fit m8, same has happened to my aerial but i was trying to find a OEM replacement but these should fit, even if u have to cut the aerial and put a connector on the end. It shouldnt come to that but most aerials are the same bit like tv aerials (co-axial) so if the worst comes to the worst you can put a connector on! but the seller does say its a direct replacement for OEM. so it worth a try and post a pic with the finished result cos im interested wot it will look like!
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    I'm thinking of doing the same. How much of a b^$!^rd is to replace the aerial base?
    I would imagine that quite a bit of the roof and rear q-panel trim needs to come off, or is this much easier than I think?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    I read that peeps remove part of the headliner by the lights at the back 10mm screws I think..not that hard (this was after my stealers replaced mine for a ton!)
    bl_1969's Avatar
    Roads? We Dont Need Roads!!!!
    Apr 2008
    351
    I did mine but I have an A3 so not sure for you guys.
    There are map lights at the back of the car for the passengers.... pop that panel out - easy peesy. Then you will see a bolt that holds the aerial base to the roof. unscrew that, that part was a bit of a pain as I was not using the right tools but anyhows.... once that's off, the rest is plain sailing. Swap the old base for the new and Robert's yer mothers brother.
    Tip....
    When tightening up the bolt... either get someone to stand at the back and keep an eye/hold the base so it does not mis-align or like what I did... put bolt back on.... tighten, go out check, then tighten again, check again etc etc.
    Maybe that will help ya's. About 15 mins to do I reckon.
    Baz
    Car: A3 1.8T QS (ARY)
    Mods: Revo Stage 2, Milltek, K&N, Forge 007p, B8's & Eibach Springs, 312MM OEM Brakes, BBS LM's, Light Pack, Ally TT Pedals, New Audi Gear Knob, Int LED's
    Wish List: ARB's, FMIC, Hose's, Maybe A Clean Engine Bay and Free Petrol
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    yup removing the roof lining is an arse cos the middle trim panel which needs to come off is interlocked with the side trim, i broke some clips getin it back on but need to remove as the aerial connector wasnt accessable through the hole where the light fits
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    Quote Originally Posted by voorhees View Post
    That's ridiculous!!! Then again, that's how they get their name.
    I might give it a go then... sounds easier than thought.
    S£'s Avatar
    Mar 2008
    Suffolk
    669
    I just popped the map lights console off and it looks quite easy, couldn't see the connector though as it was cable tied together further in.
    Question is now, which one, the fin it's self or the stubby golf one?? and do i leave them black or paint them?
    Carpy25's Avatar
    Oct 2007
    272
    I have the second type of your links , mine is a radio/satnat type and my conections are different to standard still not conected those yet so can't comment on how the radio sounds , fits the suqare hole in the roof single bolt , and as said 5 mins job done by removing rear map lights
    the second link has the fitting that would fit straight on to my 2001 model A3
    Rob
    S£'s Avatar
    Mar 2008
    Suffolk
    669
    I like that Carpy!!
