Monster MotorsportChris Nott
    Jun 2004
    South Wales
    47
    Rear shocks and bushes
    When my car was in the stealers yesterday for an ESP fault,(see other post) I also asked them to look at the rear end as I have been noticing a squeak at low speed. The problem seems to be rear bushes on the tie bar ( one thats above the driveshaft as you look at the rear end, sorry don't know correct term!)Also they said that bushes on bottom of rear shocks are worn, resulting in needing two rear shocks. Although the shocks are not expensive, the dealer labour charge of an hour each is! Can these shocks be fitted fairly easily myself? I have done shocks on other cars before, but am very wary of damaging another ESP sensor, if there are any in this area.
    Also is it worth uprating these rear bushes, or just replacing them with originals??
    Thanks,
    Chris
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: Rear shocks and bushes
    [ QUOTE ]
    Thanks,
    Chris
    [/ QUOTE ]
    If im not mistaken, ESP sensor is ABS sensor...
    I wouldnt pay someone to o the rear shocks. Well easy job! Take you 2 hours max.
    Rich
    Jun 2004
    South Wales
    47
    What about these bushes Rich?
