Chris NottSky Insurance
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,852
    can anyone help s3 missfire W-REG
    car misfiring , plenty of power still,replaced all 4 coilpacks now this is what i got with vag-com:
    16514-oxygen lambda sensor B1.S1 malfunction in circuit PO130-35-10 INTERMITTENT
    16795-secondary air injection system incorrect flow PO411 35-10 INTERMITTENT
    ALSO ON GROUP 41 found this if it means anything :::::0.70kohm htg s1 on.........this keeps flashing to off htgs1 on / off
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Have you looked on the ross tech wiki for this code? - it list possible faults and might be a good place to start?
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Quote Originally Posted by vw754 View Post
    16514/P0130/000304 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
    Possible Causes
    • Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1 faulty
    Possible Solutions
    • Check Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1
    16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
    Possible Solutions
    • Check Fuel Pump Relay (J17)
    • Check Hoses/Pipes to/between Components
    • Check Secondary Air Injection Pump (V101)
    • Check Secondary Air Injection Pump Relay (J299)
    • Check Secondary Air Injection Solenoid Valve (N112)
    For future reference: wiki.ross-tech.com is a great resource
