Monster MotorsportChris Nott
Results 1 to 16 of 16
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,568
    Door open warning help
    Been getting every now and then a warning on the DIS about the drivers door being open when it is not.......about once a week
    Anyone had this and if so have you managed to cure it yourself?
    Called Audi and its booked in, but said if it is to be serviced/oiled etc I will pay for it otherwise if replaced it will be done under warranty.
    Feb 2004
    Middlesex
    79
    Re: Door open warning help
    I also have this problem on my A3, i notice it only plays up in hot weather, i can only assume that some thing is expanding in the heat.
    This also has a knock on effect that when lock the car it some time thinks that the door is still open and doesn't set the alarm fully (if at all).
    Anito's Avatar
    Dec 2003
    Chester
    429
    I had a similar problem on my A4, except this was failing to tell me a door was open [img]/ubbthreads/images/graemlins/mad.gif[/img]
    They changed the part under warranty
    pazaz's Avatar
    May 2004
    S.Wales
    316
    Mines doing it all the time [img]/ubbthreads/images/graemlins/froggie_red.gif[/img]
    Its out of warranty so i hope its not too expensive..
    Tried some Wd40 but still the same.
    darkspin's Avatar
    Mar 2004
    Surrey
    44
    surprise surprise im having the same issue also, ive noticed that it plays up in the heat otherwise its ok on cooler days. When i called my local Audi dealer they said the cost of it depends on what needs doing so it ranged from 100 to 500 [img]/ubbthreads/images/graemlins/shocked.gif[/img] but im assuming it shouldnt be latter really
    chimmo's Avatar
    Nov 2003
    Cambridgeshire
    59
    I'll add myself to this list as I had the exact same problem with my A3 last year...
    Replacement door lock fitted resolved the problem, fortunately for me all done under warranyy. The price for the job against my car was 149.33 but I couldn't tell you if that's the cost of the part only or including fitting too.... [img]/ubbthreads/images/graemlins/crazy.gif[/img] as it was done under warranty
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    me too, drivers side.
    1st occurance last week, car was HOT. opening and slammin the door a few times sorted it.... for now. [img]/ubbthreads/images/graemlins/smile.gif[/img]
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    The drivers door usually gets used alot more than the passenger door.
    Simple wear and tear I guess.
    It costs a bit as you need to remove the door subframe to get to it.
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    my passenger side is playing up with the engine off open the door and the dome light comes on with the engine running with the door open it flashes like a disco waiting for maidstone audi to change it under warranty
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,568
    I had that too.
    Seems to be behaving at the moment
    Jun 2003
    Hythe, Kent
    1,180
    Had the same on an older A3 of mine, only in warm weather.
    The car does lock but it does not set the alarm!
    Kev.
    Aug 2003
    Kent
    123
    [ QUOTE ]
    [/ QUOTE ]
    You'll be waiting quite a while for that then!!! [img]/ubbthreads/images/graemlins/lol.gif[/img]
    I was going to get my service done there (2nd AVS) they wanted 360.... plus a 3 week waiting list!
    Going to get it done in Plymouth, when I visit my other half, for only 275 & any time after a week [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
    imported_alwinharrison
    I think I was on it for about an hour and a half.
    The worst bit is aligning the door subframe assembly up when you replace it in the door. It fixes with four Torx bolts (Tx 45 I think), the bottom two have wedge shims behind to alter the angle of the door frame/glass assembly, and the whole thing is height adjustable also
    Needs a bit of fiddling to get the door closure fit right. Make sure the door fit is OK before refitting the door trim.
    otherwise if you have done a bit its fairly straightforward.
    Mine got worse over six months or so, at first it was only doing it very occasionly when car had been in the sun.
    In the finish it would do it almost every time the car had been driven a while.
    Since stripping and lubeing the switch it has been behaving.( Up to press)
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    I had the same problem with my old 1.8SE, got it sorted by Audi somehow, not sure what was wrong
    imported_ashs3
    I had the same thing, phoned my dealer and they said "bring it in, it is the door lock that needs replacing, it's a common problem on the S3 drivers door" so took it in and they sorted it under warranty [img]/ubbthreads/images/graemlins/grin.gif[/img]
