Badger5Chris Nott
Results 1 to 1 of 1
    Sep 2008
    Cape Town, South Africa
    22
    Please help me with my logs from Vag com
    Ok guys, i've posted this before, but here goes... When running my car in 4th,5th and 6th the car experiences a flatspot at about 6000rpm, it does not occur at the same rpm all the time.
    My tuner had a look at my logs and thought that my wastegate actuator needs to be adjusted as my actual vs requested boost are not matching up in midrange rpm. Can someone please take a look at my logs and check this is normal or something i should worry about. I was of the opinion that a remap doesn't require any other fiddling. Why should i now have to adjust the actuator? I have "bolded" where the problem occurs.
    Current upgrades: FRC remap, Forge DV, Forge TIP
