Monster MotorsportChris Nott
Results 1 to 8 of 8
Thread: hi guys
    imported_andy999r
    hi guys
    Hi new member here, nogaro blue s3, one of the last to be registered. Enjoying my S3, until it started to lose power then go mad then lose power.....etc. Turns out it was my n75 valve [img]/ubbthreads/images/graemlins/shocked.gif[/img]
    Northampton Audi sorted it first time[img]/ubbthreads/images/graemlins/beerchug.gif[/img] Aparantly this is something to do with the dump valve.......
    pazaz's Avatar
    May 2004
    S.Wales
    316
    Re: hi guys
    Welcome [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Nice choice of colour and glad your problem is now sorted.
    Good luck from here on in!! [img]/ubbthreads/images/graemlins/laugh.gif[/img]
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,416
    Re: hi guys
    The standard Bosch DV fails.........quite common.
    Quite a lot of us have upgraded it to an AMD Viper or Forge equivalent.
    imported_andy999r
    Re: hi guys
    This n75 valve isnt the dump valve, its apparantly an electronic control over the dump valve? My car was over boosting, the traction control light was then coming on sensing too much something or other. this then caused the engine to protect itself by dumping all the boost, hence loads of power followed by no power.....still sorted now.
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Re: hi guys
    so the n75 opens and shuts the dv then?
    Sep 2003
    Manchester
    340
    Re: hi guys
    [ QUOTE ]
    [/ QUOTE ]
    how did u fix it?
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: hi guys
    [ QUOTE ]
    [/ QUOTE ]
    No. Basically, the N75 tells the ECS how much to boost... but the ECU has tolerances so can go over the top. Someone will correct me if im wrong
    Rich
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Re: hi guys
    so what opens the dv
