Sky InsuranceAH Fabrications
    swatchuk's Avatar
    Nov 2008
    206
    Which tie bar to change
    I'm changing all my suspension items at the weekend, and i have got the KW adjustable tie arms. I had a quick look under the car yesterday and noticed there were 2 bars on each side. Or am I looking at the wrong part?? Anyway, asuming i'm looking at the right part, Which one do i change??
    Any help or advice is appriciated.
    Thanks, Mark
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Bottom ones mate, the KW's have a section of steel plate to bolt the Xenon light leveller too.
    Here are some pics I took when I did mine last weekend:
    http://i84.photobucket.com/albums/k3...S3/Suspension/
    Make sure you undo the leveller arm mechanism before you undo the tie bar though as you are likely to break off the plastic leveller arm.
    <tuffty/>
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    I can vouch for that
    s3ollie's Avatar
    Jan 2007
    749
    defo change the bottom bar. i changed the top on at first but couldn't get get the correct toe setting so changed then to the bottom and now can set the correct toe.
    8P S3
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    i did the top buthad to move to the bottom as it wouldn`t track up right some people have had no issues at the top but a few have
    red to red black to black blue to bits
    swatchuk's Avatar
    Nov 2008
    206
    Thanks for the replys guys. Pics are good 2 tuffy, cheers. I'll be sure to undo that then as i'm guessing they wont be cheap to replace.
    Thanks again
    Mark
