EM TuningChris Nott
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    DV's a little help please
    I dare say it's been mentioned many times before but i'm strugling to find my answer via the search function...
    What are the real world advantages of fitting a forge recirc dump valve ?? i know the oem's are prone to leaks but other than that it won't make me any more power will it ?? i'm hopeless when it comes to turbo engines and i just can't quite get my head round why someone would wanna fork out 80 for something that the oem version does just aswell for a fraction of the cost.... i'm an engineer so all i need is mechanical explination of why it's a good investment
    regards Mark
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,158
    The forge DV/recirc valve has a metal piston in it whereas the standard valve uses a rubber diaphram which are prone to splitting. You wont see any more power and there are a lot of owners on here running the standard valve with a remap without a problem. It really just depends on whether you want to replace the standard valve whenever the diaphram splits or spend the 80 for the forge vavle which should last longer.
    My car had a forge valve when I bought it so I cant comment on the standard valve but I have had turbo cars before running DVs with rubber diaphrams that would regularly split. Personally if I was you i'd keep the standard valve unless it was causing you problems.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    s3 tys
    Oct 2008
    St austell, Cornwall
    88
    well have just gone for the forge splitter r valve my self is more expensive but gives audio sound off like a blow off valve plus is realiable and adjustable for the boost so if ya plannin a remap got told this would be better but many on hear say dont like the dump valve sound but sounds fine to me lol not to chavy
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    the splitR valve isnt chavvy at all its not like a proper dump valve i like the subtle sound of my splitR, think people are to quick to slate it when they havent heared one
    s3 tys
    Oct 2008
    88
    i agree like the sound my splitter r makes to
