DV's a little help please
666markyboy
Oldham, Manchester
I dare say it's been mentioned many times before but i'm strugling to find my answer via the search function...
What are the real world advantages of fitting a forge recirc dump valve ?? i know the oem's are prone to leaks but other than that it won't make me any more power will it ?? i'm hopeless when it comes to turbo engines and i just can't quite get my head round why someone would wanna fork out £80 for something that the oem version does just aswell for a fraction of the cost.... i'm an engineer so all i need is mechanical explination of why it's a good investment :keule:
regards Mark
The forge DV/recirc valve has a metal piston in it whereas the standard valve uses a rubber diaphram which are prone to splitting. You wont see any more power and there are a lot of owners on here running the standard valve with a remap without a problem. It really just depends on whether you want to replace the standard valve whenever the diaphram splits or spend the £80 for the forge vavle which should last longer.
My car had a forge valve when I bought it so I cant comment on the standard valve but I have had turbo cars before running DVs with rubber diaphrams that would regularly split. Personally if I was you i'd keep the standard valve unless it was causing you problems.
well have just gone for the forge splitter r valve my self is more expensive but gives audio sound off like a blow off valve plus is realiable and adjustable for the boost so if ya plannin a remap got told this would be better but many on hear say dont like the dump valve sound but sounds fine to me lol not to chavy
the splitR valve isnt chavvy at all its not like a proper dump valve i like the subtle sound of my splitR, think people are to quick to slate it when they havent heared one
6
683
A
10
506
