JMB RetrofitsVolks Autos
Results 1 to 8 of 8
Thread: Grinding Noise
    Apr 2004
    London
    6
    Grinding Noise
    Hi all,
    I am new to this forum and was wondering if someoine could be of help.
    I have a A3 1.8T and when I lift off I hear a grinding noise and there is a vibration coming throught the clutch pedal!!
    Any ideas as to what it is?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: Grinding Noise
    Does the sound go with engine speed or road speed?
    Apr 2004
    London
    6
    Re: Grinding Noise
    it goes with the engine speed, when i'm decelerating.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: Grinding Noise
    Does the sound dissapear if you put the clutch pedal in?
    Apr 2004
    London
    6
    Re: Grinding Noise
    it goes when I fully depress it - I feel the vibration coming through the clutch pedal
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: Grinding Noise
    Okay doke, just wanted to make sure it wasn't to do with the gearbox wheels or engine.
    If the clutch bites okay and the car drives alright except for this noise, then it sounds like a dry or split release bearing.
    Unfortunatley this means the box has to come of to fix it. Probably worth doing the clutch at the same time.
    BTW, don't take my word as gospel, and get a second opinion on this.
    Hope that helps.
    Apr 2004
    London
    6
    Re: Grinding Noise
    thanks for the help
    Apr 2004
    London
    6
    Re: Grinding Noise
    Would the car still be safe to drive?
