Badger5JMB Retrofits
    nickrex's Avatar
    Oct 2008
    45
    Another pesky CIL light!!
    Hi all. After thinking all has been well with the car for a couple of months, it has once again thrown a wobbler and given me the CIL light. Ran Vagcom and it is showing this.
    Address 01 -------------------------------------------------------
    Controller: 06A 906 032 FC
    Component: 1.8L R4/5VT 0002
    Coding: 11500
    Shop #: WSC 06435
    WAUZZZ8LZ1A087100 AUZ7Z0Y1760712
    2 Faults Found:
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-00 - -
    17545 - Shareware Version. To Decode all DTCs
    Now I know that the 17545 error is system running rich and I have got a dodgy thermostat at the moment(Usual sitting about 70 degrees trick) which a haven't got round to changing yet. The DV was replaced 3 months ago and I cant find any splits so I dont know why this is showing as faulty.
    My guess is that the thermostat is the culprit for the rich running but if anyone has had a similar problem then I would appreciate any feedback. Also could the 2 faults be related? I have cleared the codes for now and the light is out but time will tell I suppose. In the meantime I really must get round to the dreaded thermostat job!
    Look forward to any advice.
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Sounds like you might have a boost leak.
    http://wiki.ross-tech.com/index.php/17705/P1297/004759
    Also try cleaning the MAF and throttle body clean and alignment <-- these were causing my old A3 to trigger a Check Engine Light and same error.
    Throttle Body clean info - http://uk-mkivs.net/forums/t/127279.aspx
    Throttle Body alignment info - http://www.ross-tech.com/vag-com/cars/throttlebody.html
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    PS: Find someone with a full version of Vag-Com as you might be getting more errors than the shareware version will show.
    AS3TOM's Avatar
    Jan 2009
    Blackpool
    188
    where can you get the full version of vagcom from?
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    Well, what I meant was, get an official VagCom dongle from Ross-Tech, which will activate the latest version of VagCom for you. http://www.ross-tech.com/
    nickrex's Avatar
    Oct 2008
    45
    Quote Originally Posted by leshkin View Post
    Hi there. The MAF is virtually brand new and as I've said the DV is virtually new aswell. I suppose The next thing would be to check closer for any hose splits.
