Monster MotorsportEM Tuning
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By paul8206
Thread: Running temperature
    Mar 2009
    6
    Running temperature
    1998 1.8T Automatic A3
    Hello,
    What is the normal running temp. of the car (i.e. on the dashboard gauge)?
    Only asking as after, say, a 10 mile run and I'm waiting at traffic lights, the temperature seems to rise significantly (but not overheating).
    Whilst I'm at a standstill and running, I get a bit of a fumey/petrol smell through the air/heater outlets as well.
    Once I'm driving away, the temperature drops back off and the fumey smell disappears.
    Can anyone specify a problem ?
    I've also noticed that the radiator fan 30A fuse (F16) is missing from the dashboard fusebox. Is this significant ?
    Thanks.
    Darren4's Avatar
    Feb 2009
    Surrey
    186
    Should be bang on 90 after it's warmed up
    DEMON JAMS
    mine normaly warms up and sits bang on 90 degrees and doesnt really budge, dont know what the fumey smell could be about, sorry couldnt be of more help mate
    dan77's Avatar
    dan77
    Dec 2008
    Down south,
    195
    if theres no fuse for the fan, the fan wont run, so if your sat at traffic lights theres no airflow into the radiotor to cool it, the temperature should stay spot on 90degrees after its warmed up all the time, if going above 90 when your not movin youv got a problem, first thing to do would be to get a fuse or check if the fan actually runs, if the temp drops below 90 when your drivin around (just like mine did) you have a not so serious problem, id say check the thermostat as thats what it was on mine, hope this helps
    A3 1.8T sport, revo stage 1, Forge 007, Green cotton panel filter, TTpedals. . . . . SOLD
    Golf GTTDI 130 . . . . . SOLD
    Current 2006 A3 2.0TDI Quattro S-Line, Revo stage one, chrome pedals, black grill, full interior and number plate LEDs retro fitted cruise control,
    Mar 2009
    6
    Thanks for the replies - I'll give it another check but maybe everythings OK.
    I did buy a new fuse but then noticed that there doesn't appear to be the connections in the fuse space for the fuse to plug into (perhaps there isn't supposed to be a fuse placed here for my model ?).
    The temperature doesn't go above 90 when I'm stopped (e.g. in traffic) but I've noticed that most of the time the gauge is reading 60 or less when I'm under normal running conditions.
    Is this the norm ?
    P.S. the fume problem was caused by a broken breather pipe that I've fixed.
    Aug 2004
    526
    most likely needs a new thermostat and then temp will rise and stay constant
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    Also - with reference to the fumes, check that the black hose is connected to the bottom part of the air filter box as if it is left unplugged (they do snap off sometimes) the crankcase fumes will be collected by the heater and you will essentially be breathing these fumes in.
    The hose is a hard corrugated pipe made from black plastic, not rubber and is push-fitted to the airbox near the gearbox side. It's also worthwhile changing the temp sender to the newer 'green' top one and if your changing the thermostat, get yourself a new dipstick tube too, these break very easily!
    Temp sender is about 22, thermostat about 12, dipstick tube 4.
    Imteyaz.
    Apr 2007
    31
    I'm also thinking of changing my thermostat and wondering if u lose much coolent?i've got half a litre spare in the shed,whould that be enough to top up after?
    moosevtrsp1 likes this.
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    You tend to lose nearly all the coolant in the system as soon as the thermostat is removed, it's a good time to flush the system out if you fancy it and top up with new G12+ (2ltrs?), so in answering your question - no, you won't have enough unless you 'recycle' the coolant and top up using the half litre spare that you have.
    Imteyaz.
