Volks AutosMonster Motorsport
Results 1 to 23 of 23
    RyanGolfGTTDi's Avatar
    Feb 2009
    Bristol
    488
    Problem :( My Sump Plug.
    After doing my service on Saturday, I noticed that the sump plug (bolt) wasnt sitting nicely back in the sump, it wouldnt nip up tightly.
    It leaked some oil today so i took the bolt out drained all my oil, and now the bolt is less cooperative and i think the threads are getting nackered.
    Anybody know what i can do?
    Retap?
    Get a new Sump?
    or even just a new Bung?
    Thanks,. Ryan
    ASAP answered appreciated as im nownoff the road til its sorted.
    Audi S3 MTM
    345 BHP, K26 Turbo - MTM Manifold, Downpipe and Milltek Cat Back
    Polished Inlet - Facelift Front & Rear - Black Badges, Welly FMIC, N249 Bypass,
    To Come - Anthracite Rs4s
    FOR SALE:
    Audi S3 Genuine Chrome Mirror Caps. PM Me for Details
    Jun 2007
    446
    a new sump is about 80 mate, if thats any use
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    I'm guessing the sumps alloy so I reckon its had the thread mashed on it due to the plug being a harder material and the threads been crossed. You could try a new sump plug in the first instance but it might be a case of fitting a new sump.
    I had the same problem on a mini years ago, its a pain in the ass.
    T
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    S3 chj's Avatar
    Nov 2007
    South Wales
    296
    had the same prob my self a couple of months ago as a temp i used chemical metal over it, still you need a new sump
    S3 mods and tuning in progress
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    You could fit a helicoil, or try tapping the thread back out. Changing the sump is not an easy thing to so on most cars
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Feb 2009
    Bristol
    488
    Whats a Helicoil?
    Quote Originally Posted by A4Quattro View Post
    Audi S3 MTM
    FOR SALE:
    ash_pearce's Avatar
    Feb 2009
    Leicester
    315
    Quote Originally Posted by RyanA31.8T View Post
    Whats a Helicoil?
    http://www.emhart.com/products/helicoil.asp
    S3-Andy's Avatar
    Apr 2008
    198
    a wire metal thread insert, usualy used to repair threads or in some cases strengthen, you have to drill and re-tap the sump with a speacial tap usualy can be supplied with the helicoils, once drilled and taped screw in the insert, refit your sump plug, i dare say it will be better and stronger than your original thread mate, sorry if my explanation is a bit vague but honest its easy,
    S3-Andy's Avatar
    Apr 2008
    198
    beaten to it!!
    ash_pearce's Avatar
    Feb 2009
    Leicester
    315
    Quote Originally Posted by S3-Andy View Post
    beaten to it!!
    only just, good explanation tho!
    found this an flee bay,
    http://cgi.ebay.co.uk/VW-AUDI-1-8T-ALLOY-SUMP-1999-GOLF-TURBO-GTI_W0QQitemZ140306442956QQcmdZViewItemQQptZUK_Car sParts_Vehicles_CarParts_SM?hash=item140306442956& _trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65 %3A12|39%3A1|240%3A1318
    Feb 2009
    Bristol
    488
    I saw that on ebay, but i can wait that long, im gonna do the heli coil idea as that means that the alli sump will never be used again as the bolt uses the heli to tightenup. im surprised that the whole sump is alli.
    Thanks for the help guys.
    Anyone kow how easy/hard removing the sump is? as tahts the way i wanna do it.
    Audi S3 MTM
    FOR SALE:
    Feb 2009
    Bristol
    488
    any1 know what sizes to retap for the heli?
    Audi S3 MTM
    FOR SALE:
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    The sump is dead easy to remove on the A3, its there staring at you when you look under the car.
    A tube of sealer and one of those sumps will see it done properly
    Feb 2009
    Bristol
    488
    Im gna retap my sump and put it bk on.
    I was wondering how its fixed on i.e bolts? loads of 10mms im thikning :/
    Audi S3 MTM
    FOR SALE:
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    Mate sure the mating faces are dead clean and tighten the sump bolts in the correct order to avoid twisting the pan. Don't be tempted to squeeze loads of sealant on the faces though, it can ooze out inside the sump, then break off into balls and block up the oil pickup strainer, I have seen it happen.
    Chris
    See my images @
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    Shedloads of 10mm nuts, see if you can get hold of a 1/4" drive extension and socket, it will be easier to get at the fiddlybolts on the gearbox side, and as they don't weigh as much, it's easier on the arms too.
    I would recommend an engineering firm to get it helicoiled, they are used to doing jobs like this so would take them 15 minutes and they are likely to have the helicoils in stock too. Just make sure that there is no swarf in the sump before you refit it from drilling the sump threads out as you'll be looking at a new engine otherwise!
    Imteyaz.
    AS3TOM's Avatar
    Jan 2009
    Blackpool
    188
    could always use PTFE tape as a tempory measure, better than risking the use of sealent too!
    Apr 2009
    Ignition plug thread inserts ?
    Just bought an -99 A3, found same problem when I was about to change oil.
    Would it be possible using a ignition-plug thread inserts ? There is several repair kits available with a threading tap and steel inserts.
    Anyone knows the dimensions of the original oil plug ?
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    ^^ In my opinion
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Some of the sump bolts at the gearbox end are right fiddley *******s on the S3, well they were on mine anyway. I'd say use a helicoil and do it on the car if you want a quick / good fix.
    A very well known tuning company used too much of that sealent stuff on my car when they rebuilt the engine as I discovered when I knocked a hole in the sump and took it off, was pretty pleased none of it had broken off inside to be honest!
    Shifty's Avatar
    Avvve it!
    Oct 2007
    wales
    47
    Get someone toHelicoil it for you, had the same problem on my S3...Paid 35
    Audi OCD
    Sep 2008
    68
    I do like the idea of taking the sump off and cleaning out all the crap in there, someone on here said they did it and the oil was still golden a year later.
    Apr 2009
    Oil plug size is M14x1.5mm, same size
    as most spark plugs. Im heading off buying one of those repair kits for spark plugs, its only about 8us$ (half kilo bananas in gbp).
