AH FabricationsSky Insurance
Results 1 to 8 of 8
    DreA3Turbo's Avatar
    DreA3Turbo
    Aug 2003
    25
    AGU engine VAGCOM data
    Long time away from the forum....but have decided to show the A3 some love again
    So...in with my 1st question....
    I'm thinking about getting involved in a liquidS3 and am aware that some of the data may not populate based on the engine code that I have. For those that own AGU engines and also vagcom's, can you confirm whether or not you are able to pull the following data.....(i understand that if it can be pulled with a vagcom then it will display with a liquid)
    Engine Power
    Torque
    Boost Pressure
    Mass Air Flow
    Air Fuel Ratio
    Air intake Temp
    Exhaust Temp
    Dyno Plot
    Timing Correction Plot
    Speed timing
    Fault Codes
    The A3 is going in for some AP coilovers, powerflex bits, Forge spacers, TIP and some other goodies at AMD tomorrow so I expect I will be lighting up the forums with questions and pictures very shortly!!!
    Cheers in advance....
    Definition of a Paradox : Your Damned if you do and your Damned if you dont......So Just DO IT!!!
    A3 1.8TS | APR modchip | Forge DV | S3 Roof Spoiler | 40mm Drop | 19" B7 RS4's | S3 Black Interior | 12" JL Audio W3 | CrossFire Amp | Full C-Code | & the eyes of an Angel....
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,374
    Hi mate, I know the AGU can't display boost pressure or exhaust temp, I'm fairly sure it can do everything else, although I think AFR is show in lamda values of 0-1
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    ^^ In my opinion
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Engine Power - if it's worked out via g/s then probably
    Torque - don't think so
    Boost Pressure - no
    Mass Air Flow - yes
    Air Fuel Ratio - narrow band, so not even worth it. tiny voltage change
    Air intake Temp - yes
    Exhaust Temp - no
    Dyno Plot - if no toque reading then I'd say no.
    Timing Correction Plot - yes
    Speed timing - yes if you mean 0-60 etc
    Fault Codes - yes
    DreA3Turbo's Avatar
    DreA3Turbo
    Aug 2003
    25
    Thanks for your replies all. Think im going to raincheck the liquids3 for the moment then....starting to find the AGU lump seriously frustrating!!!
    looks like its vagcom time for me....
    freegeek's Avatar
    Jun 2008
    Dunfermline
    162
    You will see torque and the dyno plot.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    AGU engines are good for power and stronger than later A3 engines, so don't be dissapointed. I like the simpler approach personally with non of the emission stuff found on on later cars.
    freegeek, which is the measuring block for torque?
    freegeek's Avatar
    Jun 2008
    Dunfermline
    162
    You can see torque on block 122 but I don't use it, I calculate bhp and torque from the maf and rpm as it seems to be more accurate that the torque given in block 122.
