EM TuningChris Nott
Results 1 to 27 of 27
    Sep 2008
    Cape Town, South Africa
    22
    Boost issues..i think
    Hi All.
    I've owned my S3 for little over 6months now.It has a custom remap,forge DV and i've recently installed a TIP.The car goes through the first 4 gears pretty rapidly,but in 5th at about 5000rpm it seems to lose boost.This happens in 6th also,feels like it's just revving with no power.The DV still has the standard spring it came with and my peak boost according to VagCom is 1.4bar at about 4000rpm,should i be changing to a yellow spring as suggested on the forge website?For the first time since owning the car i caught a nissan (sr20) on the highway,i thought it would be a walk in the park.Through 2nd to 4th i maintained,but in 5th he leveled up and we tapped.I definitely think the s3 is stronger in 5th and 6th than mine currently is.Any suggestions would be appreciated.
    Current upgrades: FRC remap, Forge DV, Forge TIP
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    A standard S3 runs around 12psi of boost and depending on your remap you'll now be runing close to 20psi. If the 007P recirc valve comes as standard with a green spring then it would be worth your while getting a yellow one.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    cant see the spring causing this issue TBH..... i had a similar problem with losing top end boost ages ago...traced it to a T piece on top of the engine rocker cover... personally id check all pipes above the rocker and below the inlet manifold and to the left of the cam belt - then move on from there, obviously try unplugging the MAF and drivng to see if that makes a difference also...
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Tougher spring will make no difference at all if you are running the valve in the standard orientation.
    Log duty cycle and requested against actual boost to see if the car is producing what the ECU is wanting.
    If the ECU is requesting less, then there is nothing you can do particularly. Look to see if timing is backing off and air inlet temps.
    The stock N75 is just pants to be honest. Check the stuff animal mentions.
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Are you sure its not clutch slip?
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    Sep 2008
    22
    Thanks, will check all the pipe work.
    From my last Vag session, my requested vs actual boost is pretty spot one, only deviated slightly towards 6000rpm, but nothing major. Also the test was conducted in 4th gear and 5th and 6th is the problem.
    I did notice that intake temps have increased on average from 38degrees to 49degrees.
    Trying to get my graphs uploaded.
    Sep 2008
    22
    Here we go:
    This is post remap
    Westy's Avatar
    Dec 2008
    17,273
    Ah, there's your problem! You're not getting any boost at all
    Cant see the pic matey
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by HTC View Post
    So are you lot with remaps running the yellow spring or still the standard green spring? I was under the impression I would need to upgrade the spring as the green one is rated upto 15psi?
    S3 Build Thread
    Sep 2008
    22
    Bugger,i can see the pics with firefox.I also thought the yellow spring should be installed once mapped
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    if its throwing boost at the top end it could be one of the electrics id have thought..... im no expert but N249 valve, N75 etc etc.... its not doing it at peak boost which is typically your 3rd gear from what you've said so no simple solution i dont think
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    the spring issue is negligable compared to whats wrong with your car id have said.... if the DV isnt new id suggest cleaning it too as a precaution
    Sep 2008
    22
    Car is just about cool enough for me to inspect all the hoses.
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by 1animal1 View Post
    Yeah sorry I was kind of hi-jacking the thread and asking the question in general (for myself)! Though looking back on my boost graph it seems to be holding peak boost ok. Are you running the yellow spring Tim?
    S3 Build Thread
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    na westle i have a standard DV.... dont see the point in changing...... 20 for a new OEM or 80 for the forge.... i have a spare OEM too, im still on original one12 months after the map
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Pressure under boost acts on the side of the piston on the forge valve. A tougher spring won't make you hold more. Tougher spring will make the valve faster and dump less. I've run the green up to 30psi no problem. Everyday boost for mine is set at 22psi.
    You are probably pulling a bit of timing in 6th. This is where you'll see the largest intake temps if full throttle for a while. Log 6th if this is where the issues are.
    I don't think you are loosing boost. Remember the K04 does run out of puff in the higher revs.
    Westy's Avatar
    Dec 2008
    17,273
    Cheers HTC. I bought a yellow spring yesterday and I should get time to fit it and test it on Saturday so I'll do some more logging in VAG and see if there's any difference.
    S3 Build Thread
    Sep 2008
    22
    So i did some logs on Vag com. Queried Block 003 and here are the results: (Notice what happens at 6000rpm)
    Sep 2008
    22
    Anybody??
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    Did you feel the power drop off when the airflow dropped back?
    You should log, airflow, boost and timing pull all at the same time to get the best idea of what is going on.
    Gavin
    Sep 2008
    22
    Yes i can feel it back off,almost like i take my foot off the throttle.
    Westy's Avatar
    Dec 2008
    17,273
    Its a bit worrying that your throttle position changes so drastically. Have you tried resetting your throttle position, its worth a go as its a quick thing to try.
    S3 Build Thread
    Sep 2008
    22
    Yes i have reset the throttle already.My tuner seems to think its cos my requested boost vs. Actual boost is a bit out.Ie: from about 3200rpm - 4300rpm its requesting 2410mbar but actual is aroung 2540mbar.
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Black_S3 View Post
    What remap do you have. My ChippedUK map requests stupid boost that the turbo can meet but I dont have the problems that you're having.
    S3 Build Thread
    Sep 2008
    22
    It's a Freiling Racing remap.Will upload my logs shortly.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Remember the ECU has the ability to close the throttle body, open the DV etc at will. All part of the self protection.
    I would log timing pull (rather than overall timing), mass airflow, lambda, air inlet temp etc. You need to see why it's closing the throttle.
    The map might need tweaking to allow wider parameters. Might be something as simple as a bad MAF.
  28. #27
    Sep 2008
    22
    thanks for your input..
