Chris NottSky Insurance
Results 1 to 15 of 15
    Wheeler97's Avatar
    Mar 2008
    10
    Air conditioning not working???
    Today i tried to turn my aircon on but it just won't.When i press the button symbol indicating aircon comes on, and as soon as I release it is gone.
    kaizokuninja's Avatar
    Mar 2009
    Norwich
    144
    could that mean it needs re-gassing? i'm a n00b so its just a suggestion=)
    Haglos's Avatar
    jabba mapped
    Mar 2008
    242
    mine also does this but then other times it works perfect
    s3ollie's Avatar
    Jan 2007
    750
    i think it wont come on below a certain temp as the airs cold enough already. mine does it too
    8P S3
    snowed under
    Jul 2007
    162
    Yes what Ollie said, if its below a certain temp the air con will not come on, i think if you have the* displayed on the outside air temp it will not work.
    Wheeler97's Avatar
    Mar 2008
    10
    But if you press button with windshield icon it should also start the aircon, at least that used to happen
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Get it on vag com and see what comes up
    AS3TOM's Avatar
    Jan 2009
    Blackpool
    188
    for the aircon symbol to stay on the outside temp has to be above 5degrees
    Jan 2007
    198
    Also check the fuse on top of the battery
    Mine went and knocked out the fans and air-con
    J.
    Wheeler97's Avatar
    Mar 2008
    10
    You were right, after a night in garage it started working. The outside temperature does matter.
    north london... hertfordshire
    24
    this is silly though isnt it.. when you want the a/c to demist the windows you cant because the outside temp is too low.
    Oct 2009
    newcastle under lyme
    17
    I have the same problem and find it hard to stop the windscreen misting up without the aircon . Is this directly linked to the air temp sensor ? if so where is it and can anyone think of a way to fool it into thinking its a bit warmer because I'd rather have a clear screen than know if its a bit cold outside.
    Jun 2003
    World of my own
    9,813
    It doesn't just do it for fun, it's to protect part of the A/C system (can't remember which bit), but it's an important design feature.
    Alex Turner
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,593
    Quote Originally Posted by con1.8t View Post
    ...you could go oldskool and just direct hot air too the windscreen... just a thought
    A3/S3 aircon has a windscreen defrost button that does it for you too...
    <tuffty/>
    barters3's Avatar
    May 2008
    440
    My brother is an ac engineer and he told me that it will not run in cold weather,as if it did then it would cut out on low presure. The presure of the gas in the system is affected by ambient temp. So this is why it is interlocked with the outside temp sensor.
