Jacking Points!
AS3TOM
Blackpool
Hiya guys, just wondering if one of you knowledgable lot can help me out here.
I need to take the wheels of but i'm scratching my head a bit as to where the best place to jack the car up is on each corner?:search:
Dont want to risk causing any damage, so if ya can shed some light on this for me, cheers! :beerchug:
I never use the std jacking points, for the front I jack where the rear inner bolt is that holds the front lower arm. The rear I think I use where the trailing arm fixed to the chassis I`d have to look to be sure Its a automatic thing.
The standard jack goes on a lip under the car at either end. Or if your using a troley jack any solid part of the chasis is good
Thanks guys, i wont be using the standard jack that comes with the car, i'm going to be using a trolley jack!
yup and dont use the chassis as the long square columns just collapse:ohmy:
And just incace it all goes tits up, place the space saver under the car......just incase lol
12
I
imported_MattT
I
