AH FabricationsVolks Autos
Results 1 to 11 of 11
    Feb 2003
    41
    Head lamps misting up???
    Hi guys I have a 2001 (51 reg i.e. facelifted newer headlights) with non-xenon head lights, I know that Audi's have a problem for misting up headlights and I would have thought that over time the chrome bits inside would degrade. I told my Audi dealer and they have said that they only replace the head lights when there is dripping and they will not replace it if there is just condensation. Are they lying or is have others had this problem? Please advise.
    Aug 2003
    Kent
    123
    Re: Head lamps misting up???
    I had this with fog lights & they said that for all lights they only change if the water is dripping inside, rather than just condensation!!!
    Quite a common thing apparantly, especially TT head lights!!
    Feb 2003
    41
    yes that is what they told me. But I talked to a VW dealer and he said that the chrome bits would be ruined over time is this true?
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    If water is getting in, then yes!
    Rich
    Feb 2003
    41
    so that means that condensation will damage it too right.
    Jun 2004
    Netherlands
    58
    Eventually yeah..
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    Only if it stays. The reflector will rust with water over time.
    Rich
    Feb 2003
    41
    is there any way of getting audi to replace them under warantee, they have noted that there is condensation but that there was no dripping.
    Feb 2004
    Clearfield, PA
    892
    the way you could get around it is that due to them steaming up its causes the beams to fade and not work at 100% and so may cause an accident cos i cant see properly and so if i do i will sue audi due to the fact i noted the problem before hand...
    new headlamps thank you please!
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    if you have no beam image its a mot fail, you could tip some more water in them then they will have to change them!
    Apr 2004
    1,139
    It does actually say in my new audi A3 manual that condensation inside lights is perfectyl normal and acceptable and doesnt consitute a fault!
