JMB RetrofitsChris Nott
Thread: S3 Turbo Spec.
    Jan 2009
    20
    S3 Turbo Spec.
    Does anyone has stock S3 turbo specification such as what generation of K04 using and psi/bar it can generate in stock configuration, i am currently own a AMK 2001 engine which i going to do couple diagnosis under vagcom to see thr turbo boost is normal or not.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Generation will likely to be either k04-021 or 022. 023 is for BAM engines I believe.
    When logging you will see requested boost that the ECU wants to produce and actual boost measured at the MAP sensor. As long as the two values are more or less in line with each other then the turbo will be producing the correct amount of boost.
