Results 1 to 27 of 27
Thread: N249 Removal
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    N249 Removal
    I have been serching the net for what my low boost issue could be due to and whilst doing this i came across lots of threads about N249 removal to make a more smother drive with less surging as my car seems to surge at times i thought this might be a worth while mod to carry out does anyone no of a way to remove the N249 valve on a s3 with detailed pics if possible, as it could also be the cause of my lower boost levels from what i have read so be a good mod to eliminate it from my diagnosis at the same time,
    also what are the pro's and con's of doing this mod,
    jim s3's Avatar
    Oct 2006
    longbridge, birmingham
    313
    search vwvortex there is a how to on it
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    ok will do cheers for the input
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    is this the link that you meant??? as it seems he's removing alot of stuff and its not a s3 engine or does it not make a difference when removing the valve???
    jim s3's Avatar
    Oct 2006
    313
    yeah thats the one i used it as a guide
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    ive seen some people say that they simple T'd into the fpr vac hose then run a new vac line to the dv or someting or other this is the mod im intersted in i think as it seems a simple job to bypass the valve with out removing to much stuff, i really only want to do it to see if it helps i dont really want to rip my car apart to much, as if it dosent cure my problem then id contemplate reconecting the n249 so dont want to remove all of what is being removed in that thread, many thanks
    ianysm's Avatar
    Oct 2008
    UK
    1,001
    Whats an N249?
    Current: RenaultSport Clio 172
    Previous: 2001 ('51) S3 Quattro
    Previous: 2001 E46 M3 Coupe
    Previous: 2001 Civic Type R
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    http://www.seatcupra.net/forums/showthread.php?t=42406
    read the top bit, it explains what it does
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Quote Originally Posted by s3_kev View Post
    so does anyone have any info on how to carry out this mod????
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    See the links above! The Seat engine is the same as the TT/S3 engine.
    The pro's are that the DV is activated by engine pressure/vacuum rather than electronically using the vacuum chamber on top of the rocker cover. Things seem a little crisper when changing gears. It's the way traditional turbo cars operate.
    The con's. Well, the N249 is a safety device for your engine. If you overboost it can dump excess pressure as required.
    To be honest, as a mod it really makes bugger all difference. It just tidies up the engine bay and gets rid of some pipework.
    [/sarcasm]
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    i have looked at the links and it still dosent awnser my question as im looking to bypass the valve not completly remove every thing thats atached to my engine, ive seen people say about just t'ing into the fpr vac line just to bypass the valve not remove it
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    this is the thread i have read on about bypassing the n249 valve chris3 when you say you have to run a vac line from the fpr vac line to the dump valve what do you do with the line out of the n249 which would have gone to the dv do you simply cap it off???
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Like so?
    [/sarcasm]
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    ok so is that t'ing into the vacumm box on top the cam cover??? and where is the vac line going to?? the inlet manifold?? can i take that line to the fpr vac line instead.
    many thanks
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    I was trying to find some photo's of my old set up but I only have them with the engine cover on! I replaced the vac line and hard pipe all the way back to the bulkhead with some silicone tube, then tapped into that.
    The FRP vacuum line will work just the same.
    [/sarcasm]
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    cheers for your help, one last question though the line that would have gone to the dv from the n249 im guessing that will need capping off?
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    It never hurts to cap the vac lines. I just put a screw down the line and clamped it.
    [/sarcasm]
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    cheers for your help and input i shall give it ago tomorrow and see how it goes cheers chris
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    well i carried out the mod this afternoon and has worked a treat car seems to drive alot smoother now so i then thought id try puting my n75j back on as the only reason i took it off was due to surging issues and that also seems to be ok at the moment time will tell though i guess
    AS3TOM's Avatar
    Jan 2009
    Blackpool
    188
    good stuff matey, glad it gave you possitive results!
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,162
    So what was the final verdict with bypassing the valve?
    Do people think its a good idea and have you noticed any real difference. I might add it to my list of things to do for the easter weekend if its worth doing?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    for me bypassing the valve has worked a treat as my car used to surge alot under gear changes, however i believe my n249 valve was possibly shoot anyway so probably no gains if yours isnt faulty. also there will be no power gains if thats what your after.
    but i have managed to re-fit my n75j valve with no runnig problems, my management light never came on before when i had it fitted anyway so unsure if doing this mod will also stop peoples engine managemnet lights comming on with the n75j fitted, its a very good idea to have a boost gauge on the car so you can see what your boosting as the n249 valve is there to stop over boost so beware
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    I did mine last week, mainly just to tidy up the engine bay, it does run smoother than it did though
    Westy's Avatar
    Dec 2008
    17,162
    cheers guys, I may try this at the weekend and get VAG on there to keep an eye on my boost.
    S3 Build Thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Quote Originally Posted by sandip View Post
    Wish my engine was that clean and tidy
    Sep 2009
    I''ve just been doing some more stripping out for this mod this evening and have come across the following bit of kit not accounted for???
    http://www.facebook.com/photo.php?pi...3&id=533395586
    ^^ I hope that takes you to the right pic?! Anyway I know its the exhaust gas'emy air thingy but I think it needs a vacuum signal to it and I cant think what to use? Can it be left ignored??
    ps left all the valves in place although now not a part of the system and this has kept the ecu happy No warnings....
    Unfortunately no solving of the original boost issue I was hoping for either but at least it looks tidy'er and there are less lines to leak/fill.
  28. #27
    Westy's Avatar
    Dec 2008
    17,162
    That looks like the combi valve as described in the vortex link below:
    http://forums.vwvortex.com/zerothread?id=3111538
    its almost halfway down, the 2nd pic of the guy in the red jumper is holding it. Lookis like it can be ripped out.
    S3 Build Thread
