AH FabricationsBadger5
Results 1 to 33 of 33
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    A3 rear washer fix
    Thought this might be of use to a few people.
    My rear washer stopped working and all the fluid was pi$$ing out from within the engine bay so I had a look-see to try and sort it out....here's what it takes to fix it...
    This is the trunking that the pipe is inside..
    To get inside this trunking you have to remove the airbox, take out the screws that hold the top on the airbox, pull the wiring plugs, take off the jubilee clip thats on the MAF and then unbolt the airbox itself and lift it out..
    Next up is opening up the trunking, easy done but you have to lift the seal from the top of the engine bay and prise the trunking open, it should pop off easy enough.
    Once this is off you should be able to see the pipe, this is what mine looked like. As you can see the joint has come apart.
    Had a quick check to make sure there was no crud in the joint and then pushed it back together to how it should be..
    Checked it was working at this point and whacked some tape on the joint to hold it, all good as its back to normal now. Now its just put everything back as you take it off (excuse the state of the airfilter, its now had a service!!)
    Check everythings done up/connected properly and job done!. Took 20 minutes I reckon.
    This had been bugging me for ages, I thought the pipe would be buried somewhere really awkward
    Fingers crossed this will be of use to someone that has the same problem.
    T
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    as I posted in here Here's why some people's rear wash/wipe..... just not as detailed .....
    red to red black to black blue to bits
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    Good stuff lads.
    By the way Tom where id you get your battery cover from? My standard plastic one has been damaged and a big chunk of the plastic has been snapped off and I like the look of those fabric jobbies.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    It was on the car when I got it, I know my mate 1.8T Golf has the same kind of cover. Might be worth a call to the dealers and asking for a battery cover for a 2000 1.8T A3
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Kingston's Avatar
    Jun 2009
    Preston
    182
    Good thread mine has stopped working a couple of month ago will have to check this.
    Nogaro Blue 2001 S3 Quattro, Cream leather interior. Miltek Cat back, Induction kit, KO4 Hybrid Turbo, Chipped Remap, Power Boost Valve, Forge RC DV, Compbrake Racing 4 Pot Calipers with 2piece 350x32mm Conversion Front, 2 piece 330x20mm Compbrake Conversion on Back, Discs are Powervane Racing Rotors Gas slotted and internally veined. Hawk Hps Pads, Goodridge Braided lines to Calipers. Bose Symphony sound system. Compbrake Quickshift and side shift. Big thanks to www.Vagperformance.co.uk
    ikbenben's Avatar
    Belgium S3 driver
    Dec 2009
    105
    Mine also a couple of days ago.
    The fluids are leaking in the boot lit itself.
    When i open the boot it all leaks down
    2002 S3 BAM Nogaro Blue | Navigation + | Bose SS
    Samco TIP | Forge DV 007p | R32 ARB's | Powerflex dogbone bushes | H&R monotube coilovers
    waiting for a remap
    S3 Owner
    Feb 2009
    Aberdeen
    414
    My rear wash also doesn't work however i dont think its the connection as i remember trying it months ago and not seeing any leaking from the bay.. Could it be the wiper housing on the rear perhaps?
    6
    1 word LEGEND!
    mine hasnt worked since ive owned the car, went and checked this, 5mins later, i have a working washer jet!!!
    cheers fella
    Ross
    m444ty p's Avatar
    Oct 2009
    Clacton-On-Sea,Essex
    146
    Just checked mine and it was the same, works fine now
    |STAGE 1 REMAP |FORGE HOSES|18" RS4 ALLOYS|
    Feb 2008
    2,817
    might have to brave the weather and chekc this out as my rear washerjet has stopped working. nightmare on the motorways when you can tell whos behind you ( especially when its the filth! sorry tom)
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    Westy's Avatar
    Dec 2008
    17,264
    Just fixed mine. It turned out to be a blocked rear washer jet. Used a pin to clear it.
    S3 Build Thread
    davidhodgkinson's Avatar
    lancashire
    198
    I had this the other week on my S3, it was in the same place. The only "extra" task I had to do was remove the strut brace as it stops you removing the cover piece
    Was A3 1.8Ts
    Now S3
    Feb 2008
    2,817
    oh ******** how muc extra work are we talking with the strut brace??
    Ross_S4
    Aug 2009
    Dundee
    718
    have a go mate, you may not need to remove the strut brace. I certainly didn;t when i did this repair. just strip out the airbox and unclip the trunk cover and wiggle it about til it comes out. IIRC it comes out up the way between the brace and the scuttle but definately came out.
    lancashire
    198
    The strut brace is easy to remove, I removed the 3 nuts on the passenger side completely and just loosened the drivers side enough to lift the strut brace out of the way. It only takes an extra minute.
    Was A3 1.8Ts
    Now S3
    Mar 2009
    37
    About a month ago my rear washer stopped working and it was the hose coming adrift inside the tailgate, job done or so I thought as it stopped again a couple of weeks ago. It wasn't the tailgate this time and thanks to this thread I headed round to my mates garage to do this fix, except the water was appearing from under the bottle. Couldn't see how to easily remove the bottle so jacked up the car, front wheel and arch cover removed to reveal another separated connector behind the washer bottle, what a palaver, secured it all and - still no water.
    Further investigation showed water appearing inside the nearside rear wheelarch, removed trim, subwoofer, lens, various other bits and pieces and another separated joint on the wheel arch, fixed that and all is now well.
    It's a good idea to have joints which come apart with frost rather than have the hose split in some really inaccessible spot but bugger me they could have put the joints in better places. Will now be adding quality additive to bottle to try and prevent freezing in future.
    Sep 2009
    worcester
    1,097
    sweet!! mine hasnt worked since i got the car
    servicing the motor tomorrow so will check this out while im at it
    Sep 2009
    worcester
    1,097
    well looked at it today and the reason why my rear wash wasnt working was a mixture of a blocked nozzle and the connectors in the engine bay had come apart, all fixed now and in full working order, loving it!!
    Keeno's Avatar
    Spooly Spooly Boosty Boosty!
    Apr 2009
    West Sussex
    695
    Right, solve this one then!
    Reconnected the hose in the trunking, no blockage in the nozzle, no visible leaks or water anywhere. I'm thinking blockage in the piping somewhere? Question is, short of ripping my interior to pieces and checking the whole length of pipe what's going to clear it?
    Sep 2009
    worcester
    1,097
    have you checked the pump itself? can you hear it whirring when you press the wash/wipe?
    or try taking the whole assembly off the rear and make sure it aint all clogged up there
    Keeno's Avatar
    Apr 2009
    West Sussex
    695
    Quote Originally Posted by jonny87 View Post
    Yeah, the pump runs which makes me think blockage. Haven't checked the internals at the back, so that'll be the next port of call methinks!
    cheers.
    Sep 2009
    worcester
    1,097
    if that doesnt give you any joy, i was thinking maybe you could put something like mr muscle diluted in the washer bottle and see if that would unblock the pipe, i would only use a very weak solution though because i dont know how harmful it might be to the pipes!
    or even better yet if you had access to an airline, disconnect both ends of the tube and blast it through
    anything so you dont have to rip half the car apart tracing the tube
    Keeno's Avatar
    Apr 2009
    West Sussex
    695
    Good plan Stan!
    I'm feeling a trip to the farm to borrow the compressor...
    landopanda's Avatar
    Apr 2009
    Wiltshire
    143
    Thanks Tom, fixed my washer by the airbox as i could see it leaking down the front. However tried it and it is now leaking from the rear wheel arch, anyone know how to fix that one??
    2001 AMK ...Black
    Mar 2009
    37
    Try reading post 16
    Sep 2009
    worcester
    1,097
    Quote Originally Posted by Keeno View Post
    Good plan Stan!
    let me know how you get on dude
  28. #27
    a3tdi2001's Avatar
    437
    I've got washer fluid pouring out from the bump on the sill beside the nearside jacking point. Is there a joint down at this part of the body as well as the one at the top of the C pillar? If so, how easy is it to get at? Cheers.
  29. #28
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,030
    Visit 16Klappe's Instagram Channel
    That airline idea is really stupid.
    DO NOT use a compressed air line to unblock the washer lines, if there is a blockage the thin hoses will expand and split long before you push the dirt out. Then you're rogered...
    I've seen it done so many times, and no matter how careful you are it's going to end in tears 90% of the time. Just blowing on the hose with your mouth will be more than enough pressure, or failing that use something to push down the pipe and clear a blockage like a thin piece of electrical cable or wire.
    I quite often say I'm going to do things.
    Then never do them.
  30. #29
    landopanda's Avatar
    Apr 2009
    Wiltshire
    143
    Don't suppose anyone has any pictures of the joint over the rear arch??
    2001 AMK ...Black
  31. #30
    Dec 2009
    73
    Just done my rear arch. Mine had the cd changer and sub box, so had to remove both to gain access, the joint was on the top of the arch. sort of 10 aclock if you can understand what i mean
  32. #31
    19
    ive just fixed mine using this guide,bit of a pain as one of the airbox bolts was rusty but managed to get it off in the end, handy guide thanks
  33. #32
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    where abouts does the line run in or out the car? re connected the pipe in the bay a tiney squirt came out the back then nothing, held it for about 10seconds and couldnt see or hear any water leaking this time but it wasnt coming out the back! any ideas?
    also on another note, the wipe isnt steady its julky tried oiling it and hasnt worked!
    -AUDI A3 1.8T-
    coldside dumpvalve relocation kit/powerflow exhaust/k+n shielded air intake/ JOM coilovers/forge splitr/forge carbon fibre engine cover/soild flywheel conversion/REVO
  34. #33
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    ok answered my own question
    blockage in the nosle and also juddering was loads of grit and stuff in the motor! gave it a clean and a grease now works fine
    -AUDI A3 1.8T-
